barney3012
  • barney3012
  • 52.4% (Neutral)
Hi All
I am new to YAF and forum in general. I have just published a forum on a new domain I have and all is ok. How do I admin it though? I cannot find anything anywhere? There are similar posts on this site but I do not know what the admin username/password is, how would I get is? I know the password that was set up in the forums creation but not what the user name that matches it is.
I pressume once I get in as the admin / God setting I can change the adverts/appearance etc etc and so am gagging to have a play with it but cant get in
SOme one please take pity as I can find no documentation and drinking is not the answer I know but it is going that way:(
Please help me :roll:
barney3012
  • barney3012
  • 52.4% (Neutral)
Is there a default username and password?
herman_herman
No.
The Admin username and password is the one you create when you are setting up your forum.How do you now the password but not username?
barney3012
  • barney3012
  • 52.4% (Neutral)
The password I think is the one in the config file is it not? DOes that mean I can take the username out of the users table of the database?
If that does not work can I reset them some how?
barney3012
  • barney3012
  • 52.4% (Neutral)
All sorted thank you. Found the user name from the database and the password matched it
Thanks:o
