hexcoder
  • hexcoder
I am yet another person that can't integrate YAF with an existing ASP.Net site using membership. After copying my site's machineKey, authentication, membership, profile, and role manager to the YAF web.config, I ran the install which seemed to work fine. I can log in with the user I created during the install process, but when I click on the "Admin" link I get an "Object reference not set to an instance of an object" error. I can click on "Host" but if I try to save the settings, I get the same error.
Full error is below:
Server Error in '/community' Application.
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
[NullReferenceException: Object reference not set to an instance of an object.]
ASP.pages_admin_admin_ascx.__DataBind__control29(Object sender, EventArgs e) +127
System.Web.UI.Control.OnDataBinding(EventArgs e) +91
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +92
System.Web.UI.Control.DataBind() +15
System.Web.UI.Control.DataBindChildren() +201
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +101
System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +127
System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +478
System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +61
System.Web.UI.WebControls.Repeater.DataBind() +76
YAF.Pages.Admin.admin.BindActiveUserData() +246
YAF.Pages.Admin.admin.BindData() +1626
YAF.Pages.Admin.admin.Page_Load(Object sender, EventArgs e) +226
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.EventHandler.Invoke(Object sender, EventArgs e) +0
System.Web.UI.Control.OnLoad(EventArgs e) +91
System.Web.UI.Control.LoadRecursive() +74
System.Web.UI.Control.LoadRecursive() +146
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2207
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
