jpweber
  • jpweber
  • 94.4% (Exalted)
I recently upgraded from 1.95 to YAF-v1.9.6.1-RTW-SRC, and I went through the process www.ussvision.com/knowledgebase/install/default.aspx .... I actually edited my db.config and app.config manually, but everything eventually tested out successfully. But when I try to open my YAF (my knowledgebase), I get the following:
http://www.ussvision.com/knowledgebase/error404?aspxerrorpath=/knowledgebase/yaf_login.aspx
Server Error in Application "USSVISION.COM/KNOWLEDGEBASE"
Internet Information Services 7.5
Error Summary
HTTP Error 404.0 - Not Found
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
Detailed Error Information
Module IIS Web Core
Notification MapRequestHandler
Handler StaticFile
Error Code 0x80070002
Requested URL http://www.ussvision.com:80/knowledgebase/error404?aspxerrorpath=/knowledgebase/Default.aspx?g=login&=
Physical Path E:\web\ussvisionco\htdocs\knowledgebase\error404
Logon Method Anonymous
Logon User Anonymous
Failed Request Tracing Log Directory E:\web\ussvisionco\htdocs
Does anyone know a possible remedy for this? Thanks!
Jason Weber
USS Vision YAF
"Money is better than poverty, if only for financial reasons"
Error Summary
Module IIS Web Core
Handler StaticFile
Try compaying your app.config files -- there might be a setting regarding your URLs that needs to be updated. That or you have some issue regarding file locations with the IIS Application. Depending on how YAF is installed as an application, the bin files and settings in the app.config might need to be altered.
First you should run the upgrade wizzard
http://www.ussvision.com/knowledgebase/install/
It looks like there is a problem with the url rewriter does the UrlRewriter.config exists in your root folder?
jpweber
  • jpweber
  • 94.4% (Exalted)
Hey tha_watccha. I did run the upgrade wizard, and everything tested out successfully, although I had to manually edit the db.config and app.config myself. Everything else works .... like I can use the admin, and I get get in there via www.ussvision.com/advanced.aspx ....
Yes, I actually even tried using my old 1.95 urlrewriter.config, but then switched back to the 1.96.
So the entire YAF /knowledgebase/ folder is set as an application in IIS, and the urlrewriter.config is located in the /knowledgebase/ folder.
The /bin/ folder is also located in the /knowledgebase/ directory. So it's www.ussvision.com/knowledgebase/bin/ and all the .dll files are located in there. I don't know if I should have put the /bin/ in the root, so it would be www.ussvision.com/bin/ all the .dll files?
Not sure!
Jason Weber
USS Vision YAF
jpweber
  • jpweber
  • 94.4% (Exalted)
Problem solved. I have /bin/ directories with the .dll files both in the website root AND the /knowledgebase/ directory.
Additionally, I made some changes to the app,.config.
I already had:
