Okay just got off the phone with godaddy again , they told me their is a error in line 102 of the web.config file that was in the root directory from the blogengine install. So I am assuming their is some kind of compatibility issue with blogengine and yetanotherforum being installed in the same hosting account? Keep in mind the blog was going on the domain and forum on the subdomain.
I would really appreciate the help if someone could help me fix line 102 within the web.config file below ( keep in mind I am having problems even finding line 102)
<?xml version="1.0"?>
<configuration>
<configSections>
<sectionGroup name="BlogEngine">
<section name="blogProvider" requirePermission="false" type="BlogEngine.Core.Providers.BlogProviderSection, BlogEngine.Core" allowDefinition="MachineToApplication" restartOnExternalChanges="true"/>
</sectionGroup>
</configSections>
<BlogEngine>
<blogProvider defaultProvider="DbBlogProvider">
<providers>
<add name="DbBlogProvider" type="BlogEngine.Core.Providers.DbBlogProvider, BlogEngine.Core" connectionStringName="BlogEngine" />
</providers>
</blogProvider>
</BlogEngine>
<!-- configSource is not implemented in Mono.
<connectionStrings configSource="sql.config" />
<connectionStrings>
<clear/>
<add name="LocalSqlServer" connectionString="dummy"/>
<!-- Mono complains if LocalSqlServer isn't specified -->
<add name="BlogEngine" connectionString="Data Source=new0919703073031.db.4665915.hostedresource.com;User ID=new0919703073031;Password=Hitachi888;persist security info=False;initial catalog=new0919703073031;" providerName="System.Data.SqlClient"/>
</connectionStrings>
<appSettings>
<add key="BlogEngine.FileExtension" value=".aspx"/>
<!-- You can e.g. use "~/blog/" if BlogEngine.NET is not located in the root of the application -->
<add key="BlogEngine.VirtualPath" value="~/"/>
<!-- The regex used to identify mobile devices so a different theme can be shown -->
<add key="BlogEngine.MobileDevices" value="(nokia|sonyericsson|blackberry|samsung|sec\-|windows ce|motorola|mot\-|up.b|midp\-)"/>
<!-- The name of the role with administrator permissions -->
<add key="BlogEngine.AdminRole" value="Administrators"/>
<!--This value is to provide an alterantive location for storing data.-->
<add key="StorageLocation" value="~/App_Data/"/>
<!--A comma separated list of script names to hard minify. It's case-sensitive. -->
<add key="BlogEngine.HardMinify" value="blog.js,widget.js,WebResource.axd"/>
</appSettings>
<system.web>
<compilation debug="true">
<assemblies>
<add assembly="System.Management, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
<add assembly="System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
<add assembly="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
</assemblies>
</compilation>
<globalization requestEncoding="utf-8" responseEncoding="utf-8" culture="auto" uiCulture="auto"/>
<!-- Web.Config Configuration File -->
<httpRuntime enableVersionHeader="false" useFullyQualifiedRedirectUrl="true" maxRequestLength="16384" executionTimeout="3600" requestLengthDiskThreshold="16384"/>
<machineKey validationKey="D9F7287EFDE8DF4CAFF79011D5308643D8F62AE10CDF30DAB640B7399BF6C57B0269D60A23FBCCC736FC2487ED695512BA95044DE4C58DC02C2BA0C4A266454C" decryptionKey="BDAAF7E00B69BA47B37EEAC328929A06A6647D4C89FED3A7D5C52B12B23680F4" validation="SHA1" decryption="AES"/>
<authentication mode="Forms">
<forms timeout="129600" name=".AUXBLOGENGINE" protection="All" slidingExpiration="true" loginUrl="~/login.aspx" cookieless="UseCookies"/>
</authentication>
<pages enableSessionState="false" enableViewStateMac="true" enableEventValidation="true">
<controls>
<add namespace="Controls" tagPrefix="blog"/>
</controls>
</pages>
<customErrors mode="On">
<error statusCode="404" redirect="~/error404.aspx"/>
</customErrors>
<membership defaultProvider="DbMembershipProvider">
<providers>
<clear/>
<add name="SqlMembershipProvider" type="System.Web.Security.SqlMembershipProvider" connectionStringName="BlogEngine" applicationName="BlogEngine"/>
<add name="DbMembershipProvider" type="BlogEngine.Core.Providers.DbMembershipProvider, BlogEngine.Core" passwordFormat="Hashed" connectionStringName="BlogEngine"/>
</providers>
</membership>
<roleManager defaultProvider="DbRoleProvider" enabled="true" cacheRolesInCookie="true" cookieName=".BLOGENGINEROLES">
<providers>
<clear/>
<add name="SqlRoleProvider" type="System.Web.Security.SqlRoleProvider" connectionStringName="BlogEngine" applicationName="BlogEngine"/>
<add name="DbRoleProvider" type="BlogEngine.Core.Providers.DbRoleProvider, BlogEngine.Core" connectionStringName="BlogEngine"/>
</providers>
</roleManager>
<siteMap defaultProvider="PageSiteMap" enabled="true">
<providers>
<add name="PageSiteMap" description="The site map provider that reads in the .sitemap XML files." type="BlogEngine.Core.Web.Controls.PageSiteMap, BlogEngine.Core"/>
<add name="SecuritySiteMap" description="Used for authenticated users." type="System.Web.XmlSiteMapProvider, System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" securityTrimmingEnabled="true" siteMapFile="Web.sitemap"/>
</providers>
</siteMap>
<httpModules>
<add name="WwwSubDomainModule" type="BlogEngine.Core.Web.HttpModules.WwwSubDomainModule, BlogEngine.Core"/>
<add name="UrlRewrite" type="BlogEngine.Core.Web.HttpModules.UrlRewrite, BlogEngine.Core"/>
<add name="CompressionModule" type="BlogEngine.Core.Web.HttpModules.CompressionModule, BlogEngine.Core"/>
<add name="ReferrerModule" type="BlogEngine.Core.Web.HttpModules.ReferrerModule, BlogEngine.Core"/>
<!--Remove the default ASP.NET modules we don't need-->
<remove name="PassportAuthentication"/>
<remove name="Profile"/>
<remove name="AnonymousIdentification"/>
</httpModules>
<httpHandlers>
<add verb="*" path="file.axd" type="BlogEngine.Core.Web.HttpHandlers.FileHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="image.axd" type="BlogEngine.Core.Web.HttpHandlers.ImageHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="syndication.axd" type="BlogEngine.Core.Web.HttpHandlers.SyndicationHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="sitemap.axd" type="BlogEngine.Core.Web.HttpHandlers.SiteMap, BlogEngine.Core" validate="false"/>
<add verb="*" path="trackback.axd" type="BlogEngine.Core.Web.HttpHandlers.TrackbackHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="pingback.axd" type="BlogEngine.Core.Web.HttpHandlers.PingbackHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="opensearch.axd" type="BlogEngine.Core.Web.HttpHandlers.OpenSearchHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="metaweblog.axd" type="BlogEngine.Core.API.MetaWeblog.MetaWeblogHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="rsd.axd" type="BlogEngine.Core.Web.HttpHandlers.RsdHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="css.axd" type="BlogEngine.Core.Web.HttpHandlers.CssHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="js.axd" type="BlogEngine.Core.Web.HttpHandlers.JavaScriptHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="rating.axd" type="BlogEngine.Core.Web.HttpHandlers.RatingHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="opml.axd" type="BlogEngine.Core.Web.HttpHandlers.OpmlHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="blogml.axd" type="BlogEngine.Core.Web.HttpHandlers.BlogMLExportHandler, BlogEngine.Core" validate="false"/>
<add verb="*" path="sioc.axd" type="BlogEngine.Core.Web.HttpHandlers.Sioc, BlogEngine.Core" validate="false"/>
<add verb="*" path="apml.axd" type="BlogEngine.Core.Web.HttpHandlers.Apml, BlogEngine.Core" validate="false"/>
<add verb="*" path="foaf*.axd" type="BlogEngine.Core.Web.HttpHandlers.Foaf, BlogEngine.Core" validate="false"/>
</httpHandlers>
</system.web>
</configuration>
Thanks a Bunch
Jesse
