Someone tryed to register as "Guest" username, then when tryed to log in the forum gone down with the following error:
Exception Details: System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
[NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.]
YAF.Classes.Data.DB.user_guest(Object boardID) in YAF.Classes.Data\DB.cs:3605
YAF.Classes.Utils.UserMembershipHelper.IsGuestUser(Int32 userID) in YAF.Classes\YAF.Classes.Utils\MembershipHelper.cs:608
YAF.Controls.UserLink.Render(HtmlTextWriter output) in YAF.Controls\UserLink.cs:42
System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27
System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +134
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19
System.Web.UI.WebControls.Label.RenderContents(HtmlTextWriter writer) +8675327
System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) +32
System.Web.UI.Control.Render(HtmlTextWriter writer) +10
System.Web.UI.UpdatePanel.RenderChildren(HtmlTextWriter writer) +238
System.Web.UI.UpdatePanel.Render(HtmlTextWriter writer) +35
System.Web.UI.WebControls.WebControl.RenderContents(HtmlTextWriter writer) +10
YAF.Classes.Base.ForumPage.Render(HtmlTextWriter writer) in YAF.Classes.Base\ForumPage.cs:421
YAF.Forum.Render(HtmlTextWriter writer) +119
System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +163
System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +32
System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +51
System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +40
System.Web.UI.Page.Render(HtmlTextWriter writer) +29
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1266
