malichite
  • malichite
I am having a few issues with my installation. I have gotten to step 2 of 5 so far. It is able to connect to the Database and begins creating tables. Before it goes onto the next step I get
Request timed out.
Exception Details: System.Web.HttpException: Request timed out.
[HttpException (0x80004005): Request timed out.]
I have tried to refresh and start over but the same thing keeps happening. I am lost. Any help would be appreciated.
Yafnet.config is as follows
><yafnet>
	<connstr>user id=yaf;pwd=password;data source=(.\SQLEXPRESS);initial catalog=yafnet;timeout=90</connstr>
	<uploaddir>~/upload/</uploaddir>
	<boardid>1</boardid>
	<!-- Enable URL Rewriting -->
	<enableurlrewriting>false</enableurlrewriting>
	<!--logtomail>email=;server=;user=;pass=;</logtomail-->
	<!--categoryid>1</categoryid-->
	<!-- Enable these to use a custom user class "provider" -->
	<!--CustomUserAssembly>TinyGecko.YAFIntegration.dll</CustomUserAssembly>
    <CustomUserClass>TinyGecko.YAFIntegration.yafUserClass</CustomUserClass-->
</yafnet></connstr>
web.config is as follows
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
	<configSections>
		<section name="yafnet" type="yaf.SectionHandler,yaf" />
    <section name="rewriter" type="Intelligencia.UrlRewriter.Configuration.RewriterConfigurationSectionHandler, Intelligencia.UrlRewriter" />
	</configSections>
	<yafnet configSource="yafnet.config" />
	<rewriter configSource="urlrewriter.config" />
	<system.web>
    <httpModules>
      <add type="Intelligencia.UrlRewriter.RewriterHttpModule,Intelligencia.UrlRewriter" name="UrlRewriter" />
    </httpModules>
		<globalization requestEncoding="utf-8" responseEncoding="utf-8" />
		<compilation defaultLanguage="c#" debug="false" />
		<pages enableEventValidation="false" validateRequest="false" smartNavigation="false" />
		<authentication mode="Forms">
			<forms name=".YAFNET_Authentication" timeout="525600" />
		</authentication>
		<customErrors defaultRedirect="error.aspx" mode="RemoteOnly" />
		<!--trace enabled="true" pageOutput="true"/-->
		<xhtmlConformance mode="Legacy" /></system.web>
    <system.webServer>
        <modules>
            <add name="UrlRewriter" type="Intelligencia.UrlRewriter.RewriterHttpModule,Intelligencia.UrlRewriter" preCondition="managedHandler" />
        </modules>
        <validation validateIntegratedModeConfiguration="false" />
    </system.webServer>
</configuration>
malichite
  • malichite
Got it all figured out. Just retyped the entire connection string in yafnet.config and it worked. Must have had something little misstyped.
