soltys
  • soltys
  • 62.6% (Friendly)
I've noticed this error when i was sending private message
Cannot insert the value NULL into column 'IsRead', table 'ITMWB_Forum.dbo.yaf_UserPMessage'; column does not allow nulls. INSERT fails.
The statement has been terminated.
Line 324:					messageFlags.IsBBCode = _editor.UsesBBCode;
Line 325:
Line 326:					DB.pmessage_save( PageContext.PageUserID, recipientID [i], Subject.Text, body, messageFlags.BitValue );
Line 327:
Line 328:					if ( PageContext.BoardSettings.AllowPMEmailNotification )
Jesterking
I get the same error message when I allow PMs.
I have searched for the answer but have been unsuccessful.
Is there something that I'm missing?
soltys
  • soltys
  • 62.6% (Friendly)
I've solved it modyfying deafult values in db tables.
But another error is that when you send pm..and then another user recieves it..message is still unread..
soltys
  • soltys
  • 62.6% (Friendly)
Does any one have the same problem?
soltys
  • soltys
  • 62.6% (Friendly)
Nevermind 🙂
I've made changes to procedure to update isread column.
billyboy
can y'all post your modifications or push a patch through svn, or,or...
soltys
  • soltys
  • 62.6% (Friendly)
As a solution to null values in DB. I don't remember what tables shuold you modify...anyway check tables related with pmmessages and chcek wchich coulmns don't have default values..
For marking read messages:
modify "yaf_pmessage_markread" add " isread = 1" after update on flags.
For message archive:
modify "yaf_pmessage_archive" add " isarchived = 1" after update on flags.
That's all. Should work now 🙂
Something didn't upgrade correctly here. IsRead is a calculated field in v1.9.3.
Run this sql:
update yaf_UserPMessage set Flags = IsRead where Flags IS NULL
update yaf_UserPMessage set Flags = 1 where Flags IS NULL
GO
alter table yaf_UserPMessage drop column IsRead
GO
alter table yaf_UserPMessage ADD [IsRead] AS (CONVERT([bit],sign([Flags]&(1)),(0)))
GO
soltys
  • soltys
  • 62.6% (Friendly)
And same solution with archive pms?
Does my solution posted above has any sence? I mean..will it work in a long term 😃
The problem is that your DB didn't convert properly. I'm not modifying the code because your version of the DB is incorrect.
