Neven
  • Neven
  • 0% ()
  • YAF MVP Topic Starter
18 years ago
Some time soon we'll desperately need a full features list.
Here's what I've (com)piled .
Since I am not an original English speaker I'd like someone who is, to check my grammar and style (the text passed spelling check.)
I've separated the features in three groups but I was unable to sort them inside groups to make more sense than that.
I need more help on that!
Also, feel free to improve this list any way you wish.
TECH FEATURES
  • Quick and easy installation.
  • 100% ASP.NET.
  • Versions for dot NET 1.1 (no further development) and dot NET 2.0.
  • MS-SQL database.
  • Available as stand-alone application, DotNetNuke and Rainbow portal Module.
  • Writen in C#; source available under GPL.
  • ADMINISTRATIVE FEATURES:
  • Web based administration.
  • Unlimited number of boards forums, categories, and messages.
  • Unlimited user groups, and ranks.
  • Rank images
  • Multilingual support (also for RTL languages) (**if Omid  wishes to share his code)
  • Unicode (UTF-8) encoding
  • Template-based design.
  • Email verification.*
  • Open links in new window*
  • Set max attachment size
  • Set number of posts/topics per page
  • Store images in Database or in filesystem.
  • Ranks in ladder system (based on number of posts) or independent of the number of posts.
  • Access rights based on group membership; Option to hide forums when user has no access.
  • Move topics to other forums.
  • Administrators can mass email to all users or specific group.
  • Supports smileys/emoticons (.PAK compatible).
  • Remove nested quotes option
  • MD5 Encrypted passwords
  • IP banning.
  • Bad words filter
  • Possibility to implement various formated text editors (FCK, FreeTextBox)
  • Set HTML tags that are allowed in posts using formated text editors.
  • Set Number of seconds before another post can be entered. (Does not apply to admins or mods.)
  • Set maximum avatar file size and dimensions (in pixels)
  • Option to disable new user registrations.
  • Suspend membership (no access to the forum)
  • If the forum is moderated, posts have to be approved by a moderator. (Option; Does not apply to admins or mods.)
  • USER FEATURES
  • Full BBCode support
  • Date and number formatting based upon the user's browser settings.
  • All dates and times in local time zone for registered users.
  • Users can pick their own language and theme.*
  • Users can collapse the panes of the forum.
  • Threaded view for topics*
  • Includes forum private messaging.*
  • Receive an email notification for a new private message (user option)
  • Send e-mails, MSN Messenger, Yahoo Messenger, AIM, and ICQ instant messages*
  • RSS feeds.
  • Quick reply.
  • Upload attachments*
  • Signatures*
  • Remote and uploaded avatars*
  • Polls can be added to posts*
  • Member list.
  • Member profiles.
  • Active topics list.
  • Latest posts list.
  • Active users list.
  • Print topics.
  • Email topics.
  • Email notifications for new posts in forums or in topics.
  • View and delete subscriptions from the user control panel.
  • Change password in control panel.
  • Reset forgotten password.
  • (*if set in host settings)
... But trust me on the sunscreen!
There not bugs(in YAF)...it's either un-defined features or exceptions to expected behavior!!
test2005 wrote:
18 years ago
Now you have been keeping yourself busy!!!:p 😛 😛
The list looks perfect to me.
The only thing I would change (personal preference) is numbering each item. I've found that makes discussing app upgrade lists easier.
While I'm on it, for item 12 of ADMINISTRATIVE FEATURES, SQL2005 has a new image data type (or revamped?). Since virus(s) can now travel via images, my boss has had me move all filesystem images into the database for security. Wouldn't that be a good idea here?
BTW...2 weeks in Italy...forgot the sunscreen!!!!:oops:
Neven
  • Neven
  • 0% ()
17 years ago
How "They"'ve done it 😉
http://www.simplemachines.org/about/features.php
test2005 wrote:
17 years ago
Very nice! Shouldn't be hard to create a simple HTML page that lists what you've got above!!! You could add it as a (hard coded) button to main menu!!
17 years ago
Stickied so this doesn't get lost in the ether....
DJGray
  • DJGray
  • 88.8% (Honored)
17 years ago
As a new user of YAF, I'd like to suggest we (I'm including myself here) begin documentation/user guides for each of these features. This is clearly an excellent forum, but it is lacking documentation on use and administration of these features. I don't propose that this get done this week, or month, but that we just pick a feature and begin the docs.
17 years ago
We've been sorely lacking documentation for a good while, please feel free to contribute its why we have a wiki :-)
guest
17 years ago
Is there any way to embed objects or upload videos in the posts.
I tried putting tag in the post after adding this tag in the accepted list of html tags from host settings but it doesn't accepts it. Rather post it as simple text.
If there is any way then is is it controllable through host/admin settings?
Nav
XeE
  • XeE
  • 84.2% (Honored)
DJGray wrote:
I have compiled a documentation ,though its related to the moderation features and some other issues, but i hope it will help you a bit. check this out.
http://forum.yetanotherforum.net/yaf_postst6040_Documentation-for-Yaf-version-1916-Hope-this-would-help.aspx
CheeRS!
XeE!!!
herman_herman
Hi
I guess it is already in :cheesy: :
1.9.3 Features
XeE
  • XeE
  • 84.2% (Honored)
Ummmm.... i didn't try 1.9.3 yet, if these features are availabe then it is really great. But if someone is using 1.9.1.6 then the documentation would be helpfull. As i have developed these features in 1.9.1.6 , anyway i'll try 1.9.3 as well. I must appreciate all the people who are contributing in these best .net forums :wink:
CheERS!!
andahope
  • andahope
Hi. Can anyone tell me if the latest version of YAF has functionality to email admin / moderators when new posts / topics are created on a moderated forum?
I have done a search on this forum and see there have been some suggestions on how to code this manually but was wondering if it had been implemented formally yet?
http://forum.yetanotherforum.net/yaf_postst5309_Email-notification-of-new-post.aspx
cheers.
doxa123
  • doxa123
  • YAF All-the-Time YAF Version: 3.1.14
what are the new features list 1.9.4 RC3 ?
wmasterj
  • wmasterj
This is a long topic :)
Can we also get better API integration for those who want to create thin clients that use YAF for storage but show it entirely their own way?
