eutychus
  • eutychus
6 months ago
I am currently running my site on YAF 2.31.15. For some reason my version check is still showing as 2.31.14 but I'll let that pass. My question is, is it safe to go directly to version 3.2.2 or should I do all the other upgrades first?
6 months ago
Version 3.2.3 is out. There was an issue with the upgrade process. Now you can directly upgrade from your version. But i still would recommend to backup the database before the upgrade.
eutychus
  • eutychus
6 months ago
I did download the newer version, but it gives me the download for the stand-alone version. I'm using the YAF Sample Application version which, I understand, has to be installed differently. Where can I download this?
6 months ago
6 months ago
Originally Posted by: eutychus
Post back on how it goes with the upgrade! I'm also using Sample Application. My upgrade would be a little bit more involved as I'd have to re-add the Chat. My members rely on that thing like crazy haha. So I might hold off until v4 and do a big update! 😁
eutychus
  • eutychus
6 months ago
Originally Posted by: Zero2Cool
I will, but be patient with me. I won't be able to try it again until next Wednesday. I like to give myself lots of elbow room in case things go south and that's the next chance that I'll have that kind of time. I'll post any issues I have in this thread for you. Or you can message me privately, if you like.
6 months ago
Absolutely zero rush! Whenever I attempt an upgrade, I try to give myself two days because there's always something that kicks my butt, lol. It's usually my changes to layout and what not 😁
eutychus
  • eutychus
5 months ago
Okay, first issue: When I try the forum I get:
Could not load file or assembly 'YAF.Types, Version=2.3.1.14, Culture=neutral, PublicKeyToken=8b49dc47f4701f66' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Also, I use the membership function to support my site and this issue comes up:
'GetUser' is not a member of 'Membership'.
Line 49: Dim userName As String = ""
Line 50: Dim MemUser As MembershipUser
Line 51: MemUser = Membership.GetUser()
Line 52: If MemUser Is Nothing Then
Line 53: Session("userName") = ""
5 months ago
Did you delete all old dlls in the bin folder before the upgrade? If not make sure there are no old dlls
If i understand correctly you want to get the current user user name. You can do this with ...
Dim userName = HttpContext.Current.User.Identity.Name
eutychus
  • eutychus
5 months ago
Yes, all dlls were deleted and replaced with the ones from the 3.2.2.Sample App.
Will try this when I get home this evening. PS. I need to get the user number as well.
5 months ago
If you deleted all dlls then its possible that you have an import namespace with a reference to the YAF.Types assembly? the current YAF.Sample 3.2.3 does not contain any references to an older YAF.Types.dll.
I assume you mean ID . If you want to get the Membership(Identity) ID its
BoardContext.Current.MembershipUser.Id
or the current yaf user id
BoardContext.Current.PageUserID
eutychus
  • eutychus
5 months ago
I'm using 3.2.2. There was an issue downloading 3.2.3 that I'll discuss later. YAF.Types does show up in my bin folder, though. And yes, the kin folder is in the root directory.
Now I get: 'BoardContext' is not declared. It may be inaccessible due to its protection level.
Line 47: Protected Sub Page_PreRender(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.PreRender
Line 48: Dim userName = HttpContext.Current.User.Identity.Name
Line 49: Dim userNumber As Integer = BoardContext.Current.MembershipUser.Id
Line 50: Dim dvpms As DataView = CType(sql_pms.Select(DataSourceSelectArguments.Empty), DataView)
Line 51: If Session("UserName") "" Then
eutychus
  • eutychus
5 months ago
Just for giggles, I tried uploading the 3.2.2 Sample Site to a fresh domain, linked it to my database and got this error:
'yaf_Message' is not a constraint.
Could not drop constraint. See previous errors.
5 months ago
you need to add the using statement for YAF.Core.Context or use....
YAF.Core.Context.BoardContext.Current.PageUserID
5 months ago
as I already wrote in Yaf 3.2.2 the upgrade process is broken. You need to use 3.2.3 if you want to upgrade.
Users browsing this topic
