Phil D
  • Phil D
  • 70.6% (Friendly)
  • YAF Forumling Topic Starter YAF Version: 4
7 months ago
Can this be done easily ?
7 months ago
Originally Posted by: Phil D
Yes. You can copy one of the existing Themes and modify it to your liking. Replacing the logo is as simply as adding a logo to the directory (I don't know it off hand) and then selecting that logo in the settings. OR you can just replace the existing logo with one of your own choosing.
Phil D
  • Phil D
  • 70.6% (Friendly)
7 months ago
Thanks for the reply - Stupid question but where are the Themes held - I cant find them in the Visual Studio Solution?
7 months ago
You will find them in the Project YAF-SqlServer and then under .../Content/Themes
 themes.png You have insufficient rights to see the content.
If you want to change the logo, then place your image in the folder .../Images/Logos. Then you can select the logo in the Settings under Admin > Settings > Board Settings > Board Logo
ora
  • ora
  • 79.4% (Friendly)
  • YAF Forumling YAF Version: v4 beta
7 months ago
Once I got the build working I was able to match my site's theme in an afternoon using the Sample project.
Phil D
  • Phil D
  • 70.6% (Friendly)
7 months ago
Yes - thanks for that - didnt realise it was that easy - though I was going to have to programatically add a style.
