GothicWizard
2 years ago
So installed fresh copy of DNN 9.11 on a new web site, got everything up and running fine. First module I installed is the newest YAF for DNN. Now the only thing the web site will display is "The page cannot be displayed because an internal server error has occurred."
I turned customErrors mode="Off" in the config file but that didn't give any new info. Same message.
See the site here; https://cyberpunk-news.online/
2 years ago
Looks like finally the dnn api dlls have been updated.
You should be able to restore the website if you update the entries in the web.config from
 <dependentAssembly xmlns="urn:schemas-microsoft-com:asm.v1">
        <assemblyIdentity name="System.Web.Http" publicKeyToken="31bf3856ad364e35" />
        <bindingRedirect oldVersion="0.0.0.0-5.2.9.0" newVersion="5.2.7.0" />
      </dependentAssembly>
to
        <bindingRedirect oldVersion="0.0.0.0-32767.32767.32767.32767" newVersion="5.2.9.0" />
and the line from
        <assemblyIdentity name="System.Web.Http.WebHost" publicKeyToken="31bf3856ad364e35" />
to
I will release an updated version soon.
GothicWizard
2 years ago
Thank for the attempt, tried to do that but still didn't work. So I just reinstalled the site. Any ETA when a fixed version will be released for DNN?
2 years ago
First i need to find the issue, then i can release an updated version. Can you upload the log files? You can find them under "Portals\_default\Logs\[Current date].log.resources"
GothicWizard
a year ago
Well I used your new version and well while it didn't crash the site this happened after I installed the module, I didn't even add it to the site yet, my entire theme/skin interface is gone. if you need any logs let me know.
a year ago
Yes, as i wrote above i would need the logs to see the error messages.
GothicWizard
a year ago
 InstallerLog20221110.resources.txt You have insufficient rights to see the content.
This is the only log file on the date in question with any data in it. I added the .txt extension on it so I could upload it. Let me know if you need anything else.
GothicWizard
a year ago
Also if you need FTP access to my site let me know and I'll send you the info via PM.
a year ago
[quote=GothicWizard;73485] InstallerLog20221110.resources.txt You have insufficient rights to see the content.
This is the only log file on the date in question with any data in it. I added the .txt extension on it so I could upload it. Let me know if you need anything else.[/quote
Its odd that there is no error log. Can you turn custom errors of in the web.config?
<customErrors mode="Off" />
Then it should show the error message on https://cyberpunk-news.online/Resources/Shared/stylesheets/dnndefault/7.0.0/default.css?cdv=54
I tried to reproduce the problem. Installed dnn 9.11.0 and then YAF 3.1.8. but i can not reproduce the isseu
a year ago
If i try to access the css files it says now "File or directory not found."
Are those files exist on the server?
