vcsharp
  • vcsharp
  • 88.4% (Honored)
5 years ago
I am trying to understand how registration user controls gets loaded into forum user control. There is no place holder control like asp:Placeholder anywhere in yaf/pages/forum.ascx, so I am confused. There must be something like a master page being used for all aspx pages in yaf i.e. there must be some base user control. I cannot figure out where is the code for base user control and how/where reguser.ascx gets loaded (i.e. source code location for this)
I have following markup for including yaf in my aspx page.
<YAF:Forum runat="server" ID="forum" BoardID="1"></YAF:Forum>
  • YAF.NET Project Lead 🤴 Answer YAF Version: 4.0.0 rc 2
5 years ago
Its in the source of the Forum control..
this.currentForumPage = (ForumPage)this.LoadControl(src);
vcsharp
  • vcsharp
  • 88.4% (Honored)
5 years ago
So, there is nothing like a master page in yaf; rather individual user controls from controls folder are added dynamically at run time for the top control, footer control, main content control and other parts every time the aspx page needs to rendered. Is that correct?
Also, the code that you mentioned has a minor part missing. The actual line of code has an underscore just before currentForumPage. The file where its found is in project yaf at following location: /classes/forum.cs.
this._currentForumPage = (ForumPage)this.LoadControl(src);
5 years ago
Correct, are you trying to add a new page to yaf?
Yes correct the old yaf uses underscores. I was referencing the Current YAF version (RC)
vcsharp
  • vcsharp
  • 88.4% (Honored)
5 years ago
Yes, I plan on doing so. The landing page after user logs in would be a custom page and not the landing page in yaf. I am still not sure if I can use the yaf framework for creating a new page or it would be better to just create it like a normal aspx page.
5 years ago
Its actually easy to add a new page. Just follow the guide from here
[post=52957]How to Add new Page[/post]
