SOul12
  • SOul12
6 years ago
I have the following error message when I run the forum for the first time after ugrading it to the latest version. Yaf run under an existing website (not standalone). Upgrade process has been done sucessfully.
Someone could help please?
Sylvain
Procedure or function yaf_forum_moderators has too many arguments specified.
Exception Details: System.Data.SqlClient.SqlException: Procedure or function yaf_forum_moderators has too many arguments specified.
[SqlException (0x80131904): Procedure or function yaf_forum_moderators has too many arguments specified.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +2555670
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +5958360
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +285
System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +4169
System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() +58
System.Data.SqlClient.SqlDataReader.get_MetaData() +89
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted) +430
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) +2598
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) +1483
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +64
System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) +240
System.Data.SqlClient.SqlCommand.ExecuteDbDataReader(CommandBehavior behavior) +41
System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader(CommandBehavior behavior) +12
System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +139
System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +136
System.Data.Common.DbDataAdapter.Fill(DataSet dataSet) +88
YAF.Types.Interfaces.Data.<>c__DisplayClass7_0.b__0(IDbCommand c) +72
YAF.Core.Data.DbAccessBase.Execute(Func`2 execFunc, IDbCommand cmd, IDbTransaction dbTransaction) +186
YAF.Types.Interfaces.Data.IDbAccessExtensions.GetDataset(IDbAccess dbAccess, IDbCommand cmd, IDbTransaction dbTransaction) +139
YAF.Types.Interfaces.Data.IDbAccessExtensions.GetData(IDbAccess dbAccess, IDbCommand cmd, IDbTransaction dbTransaction) +57
YAF.Core.Data.DynamicDbFunction.b__29_0(IDbCommand cmd) +29
YAF.Core.Data.DynamicDbFunction.DbFunctionExecute(DbFunctionType functionType, InvokeMemberBinder binder, IList`1 parameters, Func`2 executeDb, Object& result) +226
YAF.Core.Data.DynamicDbFunction.InvokeGetData(InvokeMemberBinder binder, Object[] args, Object& result) +87
YAF.Core.Data.TryInvokeMemberProxy.TryInvokeMember(InvokeMemberBinder binder, Object[] args, Object& result) +18
CallSite.Target(Closure , CallSite , Object , Int32 , Boolean ) +207
YAF.Core.Services.YafDbBroker.b__31_1(Object cdb) +260
CallSite.Target(Closure , CallSite , Func`2 , Object ) +81
YAF.Types.Interfaces.Data.IDbFunctionExtensions.GetAsDataTable(IDbFunction dbFunction, Func`2 function) +314
YAF.Core.Services.YafDbBroker.b__31_0() +45
YAF.Core.Services.Cache.HttpRuntimeCache.GetOrSetInternal(String key, Func`1 getValue, Action`1 addToCacheFunction) +299
YAF.Core.Services.Cache.HttpRuntimeCache.GetOrSet(String key, Func`1 getValue, TimeSpan timeout) +236
YAF.Core.Services.YafDbBroker.GetModerators() +133
YAF.Core.Services.YafDbBroker.BoardLayout(Int32 boardID, Int32 userID, Nullable`1 categoryID, Nullable`1 parentID) +194
YAF.Controls.ForumCategoryList.BindData() +154
YAF.Controls.ForumCategoryList.Page_Load(Object sender, EventArgs e) +5
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +51
System.Web.UI.Control.OnLoad(EventArgs e) +95
System.Web.UI.Control.LoadRecursive() +59
System.Web.UI.Control.LoadRecursive() +131
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +678
6 years ago
Did you run the upgrade wizard?
SOul12
  • SOul12
6 years ago
yes I ran this wizard. And the installation has been successful. I am surprised that if the installation succed, the forum didn't run on the first use...
