ChrisMaga
  • ChrisMaga
  • 57.2% (Neutral)
7 years ago
Hi developers,
I am transitioning from forums v2.0.0 to v.2.2.3. I downloaded YAF.NET v2.2.3 upgrade package and reached to step 4 (install screen for upgrading forums) sucessfully. When it asks me to upgrade database to the latest version (check mark on "Upgrade BBCode Extensions, File Extensions, Topic Status Lists and Spam Words") and I click "Next", it shows me the following error:
Exception Details: System.Exception: FILE:
mssql/upgrade/views.sql
ERROR:
The REFERENCES permission was denied on the object 'yaf_UserGroup', database 'yafnet', schema 'dbo'.
Cannot find the object "yaf_UserGroup" because it does not exist or you do not have permissions.
STATEMENT:
IF NOT exists (select top 1 1 from sys.objects WHERE object_id = OBJECT_ID(N'[dbo].[yaf_vaccess_group]') AND type in (N'V'))
EXEC sys.sp_executesql @statement = N'CREATE VIEW [dbo].[yaf_vaccess_group]
WITH SCHEMABINDING
AS
select
b.UserID,
c.ForumID,
d.AccessMaskID,
b.GroupID,
ReadAccess = convert(int,d.Flags & 1),
PostAccess = convert(int,d.Flags & 2),
ReplyAccess = convert(int,d.Flags & 4),
PriorityAccess = convert(int,d.Flags & 😎,
PollAccess = convert(int,d.Flags & 16),
VoteAccess = convert(int,d.Flags & 32),
ModeratorAccess = convert(int,d.Flags & 64),
EditAccess = convert(int,d.Flags & 128),
DeleteAccess = convert(int,d.Flags & 256),
UploadAccess = convert(int,d.Flags & 512),
DownloadAccess = convert(int,d.Flags & 1024),
AdminGroup = convert(int,e.Flags & 1)
from
[dbo].[yaf_UserGroup] b
INNER JOIN [dbo].[yaf_ForumAccess] c on c.GroupID=b.GroupID
INNER JOIN [dbo].[yaf_AccessMask] d on d.AccessMaskID=c.AccessMaskID
INNER JOIN [dbo].[yaf_Group] e on e.GroupID=b.GroupID'
I checked out yafnet database and "yaf_UserGroup" table is there.
Do you have any idea what could be the problem? How can I resolve this issue?
7 years ago
if you are sure that the dbo.yaf_UserGroup table exist then you need to check if the database user have the correct permissions (db owner)
ChrisMaga
  • ChrisMaga
  • 57.2% (Neutral)
7 years ago
Your are right.
It seems my database user didn't have permissions, and I had to fix it.
It works great.
