DarkLogix
  • DarkLogix
  • 63.2% (Friendly)
My web server is a 2008R2 VM and I'm trying to use a remote SQL 2014 server
lets say the names of them are 2008R2-WEB and 2008R2-SQL (since the OS is windows server 2008R2)
I created a DB in the SQL instance named YAFNET and made an AD used named YAFNET then created a SQL login for that AD user and granted it DB owner permission to the YAFNET DB.
I then extracted the contents of the zip file to D:\web\Forum\
and made a virtual directory off the default site and named the virtual directory forum.
then I copied and renamed the copy of recommended.web.config to web.config
but on browsing to https://2008r2-web/forum/install/default.aspx I get runtime error
Description: An exception occurred while processing your request. Additionally, another exception occurred while executing the custom error page for the first exception. The request has been terminated
can some one help?
DarkLogix
  • DarkLogix
  • 63.2% (Friendly)
Well I've messed with it some more and when I made a site on port 444 it worked but making it a virtual directory of my main doesn't.
https://github.com/YAFNET/YAFNET/wiki/Installation
and edited the line is app.config and copied the /bin folder but it still doesn't work
I think I got it worked out.
I made a new site using 444 then I exported that via IIS, and then imported it using IIS as an app then I set it to use a different app pool and now its not using the computer account to access sql (IE I didn't want it to use the computer account)
its a bit sluggish but it might be due to the web server's storage being slow (the SQL is using a datastore that's on SSD's)
DarkLogix
  • DarkLogix
  • 63.2% (Friendly)
Well I thought it was working but just tried to create a 2nd user (IE a non-admin) and got the following
reCAPTCHA needs to be configured with a site & secret key.
Originally Posted by: DarkLogix
Sorry but this is a known bug at the moment, even if you don't use reCaptcha simply add an site & secret key in the host settings (it doesn't matter what you enter actually). This issue will be fixed in 2.2.1.
