djzia
  • djzia
  • 54.8% (Neutral)
http://generationweb.in/ forum/ and its working fine.
I also have a wordpress blog installed.
Since search engines are indexing my forum & blog with the same domain name i wanted to move the forum to subdomain(i read somewhere that search engines treat sub domains as different websites)
I downloaded the final version of yaf(YAF-v1.9.5-FINAL-BIN) and uploaded all the files to subdomain http://forum.generationweb.in and added the necessary settings and it installed successfully.
The problem is that im unable to login using my existing username but im able to see all my posts
Im using the same database.
Could you tell me whats wrong?
I can login here http://generationweb.in/forum
but i cant login here http://forum.generationweb.in
logan
  • logan
  • YAF Leader
First guess would be that the membership sections in web config are different.
Did you use same web.config??
test
djzia
  • djzia
  • 54.8% (Neutral)
Thanks logan you are right..
Replaced the membership section from the old web.config. now im able to login.
Why is the font size so big??
And the No New Posts icon is not visible
logan
  • logan
  • YAF Leader
Set the font size in your theme.css try 12px
test
Added to the fact also; that "No New Posts" text is only showing because it can't find the image in your theme.
