srelliott
  • srelliott
  • 56% (Neutral)
I'm not sure what's wrong. I went through a fresh install for 1.9.5 RC1 and it said it was successful. But when I goto the forum and try to access the admin page, I get an error:
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Line 34:
Line 35:
Line 36: <%# YafBBCode.EncodeHTML( YafUserProfile.GetProfile( Eval("UserName").ToString() ).Location ) %>
Line 37:
Line 38:
I'm also unable to view a post, or edit the user profile. It seems like this must be membership related? It's a fresh install though.
doxa123
  • doxa123
  • YAF All-the-Time YAF Version: 3.1.14
Did you change url rewriting? for example yetanotherforum.net/yaf_ like this yetanotherforum.net/yourForumName_ ...
if there is problem on regex or something else, you can't access anywhere...
srelliott
  • srelliott
  • 56% (Neutral)
URL Rewriting is set to false in the app.config (by default).
It allows me to post a new topic, but as soon as I post it, it gives me the Object reference not set to an instance of an object error page. Then I go to the forum and the new topic is listed, but if I go to view it, I get the reference error again. It looks like the URL's are correct, as it's putting the /Forum/ in there like it should.
And I get the error mentioned in my first post if I try to access the admin area, with the username I created during setup (admin). It goes to the URL /Forum/default.aspx?g=admin_admin
srelliott
  • srelliott
  • 56% (Neutral)
I just upgraded to 1.9.5 RTW and I'm still not able to see the admin index (yaf_admin_admin.aspx) without getting the error mentioned in the first post. However, I am able to browse around other areas of the admin area if I go into the "Host" link first, then browse around the admin area from there.
Also, still can't view a post...
srelliott
  • srelliott
  • 56% (Neutral)
I've figured out what's causing the problem. It's something to do with the web.config in the root site. I have this forum setup in the "Forum" folder, which is setup as an application, and didn't think the two web.config's would conflict, but apparently they do. If I change the root site web.config to web.config.txt (to hide it), the forum works fine. Now I just need to figure out what the issue is...
Originally Posted by: srelliott
My guess is that it's related to your ASP.NET membership provider configuration.
srelliott
  • srelliott
  • 56% (Neutral)
For anyone having a similar problem, I solved it by setting the root web.config to disable inheritance.
