vijayvelidi
  • vijayvelidi
While im trying to install YAF
Method not found: 'System.Web.UI.CompositeScriptReference System.Web.UI.ScriptManager.get_CompositeScript()'.
Exception Details: System.MissingMethodException: Method not found: 'System.Web.UI.CompositeScriptReference System.Web.UI.ScriptManager.get_CompositeScript()'.
Line 229: {
Line 230: // init the popup first...
Line 231: base.OnInit(e);
Line 232:
Line 233: // make a few changes for this type of modal...
Source File: d:\YAF\App_Code\YAF\Modules\PagePopupModule.cs Line: 231
[MissingMethodException: Method not found: 'System.Web.UI.CompositeScriptReference System.Web.UI.ScriptManager.get_CompositeScript()'.]
DNA.UI.ClientScriptManager.AddCompositeScript(Control control, ScriptReference scriptReference) +0
DNA.UI.ClientScriptManager.AddCompositeScript(Control control, String name, String assembly) +41
DNA.UI.JQuery.Dialog.OnInit(EventArgs e) +191
YAF.Modules.PopupDialogNotification.OnInit(EventArgs e) in d:\YAF\App_Code\YAF\Modules\PagePopupModule.cs:231
System.Web.UI.Control.InitRecursive(Control namingContainer) +321
System.Web.UI.Control.AddedControl(Control control, Int32 index) +221
System.Web.UI.ControlCollection.Add(Control child) +146
YAF.Modules.PagePopupModule.AddErrorPopup() in d:\YAF\App_Code\YAF\Modules\PagePopupModule.cs:103
YAF.Modules.PagePopupModule.ForumControl_Init(Object sender, EventArgs e) in d:\YAF\App_Code\YAF\Modules\PagePopupModule.cs:89
System.EventHandler.Invoke(Object sender, EventArgs e) +0
System.Web.UI.Control.OnInit(EventArgs e) +99
System.Web.UI.UserControl.OnInit(EventArgs e) +74
System.Web.UI.Control.InitRecursive(Control namingContainer) +198
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +834
Version Information: Microsoft .NET Framework Version:2.0.50727.1433; ASP.NET Version:2.0.50727.1433
erudisill
I am having the same problem. Just downloaded today and installed on our server. I know I have 3.5 installed because our primary applications are compiled against 3.5. Does anyone have a clue what is going on?
clee
  • clee
I feel like it's something stupid that I am missing. 😊
Here is the error:
Server Error in '/forum' Application.
Line 229: {
Line 232:
Source File:
mydomain.com\forum\App_Code\YAF\Modules\PagePopupModule.cs Line: 231
Here are my app settings:
Here is another error:
Unable to find a theme to load. Last attempted to load "yafpro.xml" but failed.
Exception Details: System.Exception: Unable to find a theme to load. Last attempted to load "yafpro.xml" but failed.
Line 417: string src = string.Format("{0}pages/{1}.ascx", m_baseDir, this._page);
Line 418:
Line 419: string controlOverride = YafContext.Current.Theme.GetItem("PAGE_OVERRIDE", this._page.ToString(), null);
Line 420:
Line 421: if (!String.IsNullOrEmpty(controlOverride))
Source File: \mydomain.com\forum\App_Code\YAF\Forum.cs Line: 419
clee
  • clee
