pcbliss
  • pcbliss
  • 52.4% (Neutral)
I was able to set YAF up fine on my test system, but I am havig problems on my live server.
YAF Version: 1.9.3
Hosting Platform: IIS 6.0 on Windows Small Business Server 2003
Database: SQL Server Express 2008 using mixed mode authentication. YAF account is an sql account.
Running on ASP.NET 3.5.
During setup, after I put in my configuration password I am getting the following error:
Server Error in '/forum' Application.
Instance failure.
Exception Details: System.InvalidOperationException: Instance failure.
Line 545: private void FixAccess( bool bGrant )
Line 546: {
Line 547: DB.system_initialize_fixaccess(bGrant);
Line 548: }
Line 549: #endregion
Source File: c:\webfiles\forum\install\default.aspx.cs Line: 547
[InvalidOperationException: Instance failure.]
System.Data.SqlClient.TdsParser.Connect(ServerInfo serverInfo, SqlInternalConnectionTds connHandler, Boolean ignoreSniOpenTimeout, Int64 timerExpire, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity, SqlConnection owningObject) +4860547
System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, Int64 timerExpire, SqlConnection owningObject) +90
System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(String host, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, Int64 timerStart) +257
System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance) +221
System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance) +189
System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection) +185
System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options) +31
System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject) +433
System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject) +66
System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject) +499
System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) +65
System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +117
System.Data.SqlClient.SqlConnection.Open() +122
YAF.Classes.Data.YafDBConnManager.get_OpenDBConnection() +39
YAF.Classes.Data.DB.system_initialize_fixaccess(Boolean grant) +60
YAF.Install._default.FixAccess(Boolean bGrant) in c:\webfiles\forum\install\default.aspx.cs:547
YAF.Install._default.UpgradeDatabase(Boolean fullText) in c:\webfiles\forum\install\default.aspx.cs:273
YAF.Install._default.Wizard_NextButtonClick(Object sender, WizardNavigationEventArgs e) in c:\webfiles\forum\install\default.aspx.cs:205
System.Web.UI.WebControls.Wizard.OnNextButtonClick(WizardNavigationEventArgs e) +108
System.Web.UI.WebControls.Wizard.OnBubbleEvent(Object source, EventArgs e) +418
System.Web.UI.WebControls.WizardChildTable.OnBubbleEvent(Object source, EventArgs args) +19
System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +37
System.Web.UI.WebControls.Button.OnCommand(CommandEventArgs e) +118
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +166
System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
pcbliss
  • pcbliss
  • 52.4% (Neutral)
web.config follows:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
	<configSections>
		<sectionGroup name="system.web.extensions" type="System.Web.Configuration.SystemWebExtensionsSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35">
			<sectionGroup name="scripting" type="System.Web.Configuration.ScriptingSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35">
				<section name="scriptResourceHandler" type="System.Web.Configuration.ScriptingScriptResourceHandlerSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" requirePermission="false" allowDefinition="MachineToApplication"/>
				<sectionGroup name="webServices" type="System.Web.Configuration.ScriptingWebServicesSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35">
					<section name="jsonSerialization" type="System.Web.Configuration.ScriptingJsonSerializationSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" requirePermission="false" allowDefinition="Everywhere" />
					<section name="profileService" type="System.Web.Configuration.ScriptingProfileServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" requirePermission="false" allowDefinition="MachineToApplication" />
					<section name="authenticationService" type="System.Web.Configuration.ScriptingAuthenticationServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" requirePermission="false" allowDefinition="MachineToApplication" />
					<section name="roleService" type="System.Web.Configuration.ScriptingRoleServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" requirePermission="false" allowDefinition="MachineToApplication" />
				</sectionGroup>
			</sectionGroup>
		</sectionGroup>
		<section name="rewriter" type="Intelligencia.UrlRewriter.Configuration.RewriterConfigurationSectionHandler, Intelligencia.UrlRewriter" requirePermission="false"/>
	</configSections>
	<connectionStrings configSource="db.config"/>
	<appSettings configSource="app.config"/>
	<rewriter configSource="URLRewriter.config" />
	<system.net>
		<mailSettings>
			<smtp configSource="mail.config"/>
		</mailSettings>
	</system.net>
	<system.web>
		<trace enabled="false" />
		<xhtmlConformance mode="Transitional" />
		<!--<customErrors defaultRedirect="Error.aspx" mode="On"/>-->
    <customErrors defaultRedirect="Error.aspx" mode="Off" />
    <globalization requestEncoding="utf-8" responseEncoding="utf-8"/>
		<authentication mode="Forms">
			<forms name=".YAFNET_Authentication" protection="All" timeout="43200" cookieless="UseCookies"/>
		</authentication>
		<!-- Set debug to "true" to test out the system in development -->
		<!--<compilation defaultLanguage="c#" debug="false">-->
    <compilation defaultLanguage="c#" debug="true">
        <assemblies>
        <add assembly="System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
        <add assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
        <add assembly="System.Data.DataSetExtensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
        <add assembly="System.Xml.Linq, Version=3.5.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
        <add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
        <add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
        <add assembly="System.Data.Linq, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
			</assemblies>
		</compilation>
		<httpHandlers>
			<remove verb="*" path="*.asmx"/>
			<add verb="*" path="*.asmx" validate="false" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
			<add verb="*" path="*_AppService.axd" validate="false" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
			<add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" validate="false"/>
		</httpHandlers>
		<httpModules>
			<add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
			<add name="YafInitModule" type="YAF.Classes.Base.YafInitModule, YAF.Classes.Base"/>
			<add name="UrlRewriter" type="Intelligencia.UrlRewriter.RewriterHttpModule,Intelligencia.UrlRewriter" />
		</httpModules>
		<pages validateRequest="false" smartNavigation="false">
			<controls>
				<add tagPrefix="asp" namespace="System.Web.UI" assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
				<add tagPrefix="asp" namespace="System.Web.UI.WebControls" assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
				<add tagPrefix="ajaxToolkit" namespace="AjaxControlToolkit" assembly="AjaxControlToolkit"/>
				<!-- Default: use non-dynamic (compiled classes) in YAF -->
				<add tagPrefix="YAF" namespace="YAF.Classes.UI" assembly="YAF.Classes.UI" />
				<add tagPrefix="YAF" namespace="YAF.Classes.Utils" assembly="YAF.Classes.Utils" />
				<add tagPrefix="YAF" namespace="YAF.Classes.Data" assembly="YAF.Classes.Data" />
				<add tagPrefix="YAF" namespace="YAF.Controls" assembly="YAF.Controls" />
				<add tagPrefix="YAF" namespace="YAF.Controls.Statistics" assembly="YAF.Controls" />
				<!-- Optional: use dynamic classes in YAF by moving all the YAF.x directories (YAF.Classes.*, YAF.Providers)
						into the App_Code\YAF directory. Delete the associated .dll files from the \bin directory. Comment out the above
						"non-dynamic" namespaces above and enable these:
				<!--add tagPrefix="YAF" namespace="YAF.Classes.UI" />
				<add tagPrefix="YAF" namespace="YAF.Classes.Utils" />
				<add tagPrefix="YAF" namespace="YAF.Classes.Data" />
				<add tagPrefix="YAF" namespace="YAF.Controls" />
				<add tagPrefix="YAF" namespace="YAF.Controls.Statistics" /-->
				<add tagPrefix="YAF" namespace="YAF.Classes" />
				<add tagPrefix="YAF" namespace="YAF"/>
				<add tagPrefix="editor" namespace="YAF.Editor"/>
			</controls>
			<namespaces>
				<add namespace="YAF" />
				<add namespace="YAF.Classes.UI" />
				<add namespace="YAF.Classes.Utils" />
				<add namespace="YAF.Controls" />
				<add namespace="YAF.Classes.Data" />
			</namespaces>
		</pages>
		<roleManager enabled="true" defaultProvider="YafRoleProvider">
			<providers>
				<clear/>
					<add connectionStringName="yafnet" applicationName="YetAnotherForum" name="YafRoleProvider" type="YAF.Providers.Roles.YafRoleProvider"/>
			</providers>
		</roleManager>
		<membership defaultProvider="YafMembershipProvider" hashAlgorithmType="SHA1">
			<providers>
				<clear/>
				<add connectionStringName="yafnet" applicationName="YetAnotherForum" name="YafMembershipProvider" requiresUniqueEmail="true" useSalt="true" type="YAF.Providers.Membership.YafMembershipProvider"  minRequiredPasswordLength="1" minRequiredNonAlphanumericCharacters="0" />
        <!--<add connectionStringName="yafnet" applicationName="YetAnotherForum" name="YafMembershipProvider" requiresUniqueEmail="true" useSalt="true" type="YAF.Providers.Membership.YafMembershipProvider" />-->
      </providers>
		</membership>
		<profile enabled="true" defaultProvider="YafProfileProvider" inherits="YAF.Classes.Utils.YafUserProfile">
			<providers>
				<clear/>
        		<add connectionStringName="yafnet" applicationName="YetAnotherForum" name="YafProfileProvider" type="YAF.Providers.Profile.YafProfileProvider"/>
			</providers>
		</profile>
	</system.web>
	<system.web.extensions>
		<scripting>
      		<scriptResourceHandler enableCompression="true" enableCaching="true" />
		</scripting>
	</system.web.extensions>
	<system.webServer>
		<validation validateIntegratedModeConfiguration="false"/>
		<modules>
			<remove name="ScriptModule"/>
			<remove name="YafInitModule" />
			<remove name="UrlRewriter" />
			<add name="ScriptModule" preCondition="managedHandler" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
			<add name="UrlRewriter" type="Intelligencia.UrlRewriter.RewriterHttpModule,Intelligencia.UrlRewriter" preCondition="managedHandler"/>
		</modules>
		<handlers>
			<remove name="WebServiceHandlerFactory-Integrated"/>
			<remove name="ScriptHandlerFactory"/>
			<remove name="ScriptHandlerFactoryAppServices"/>
			<remove name="ScriptResource"/>
			<add name="ScriptHandlerFactory" verb="*" path="*.asmx" preCondition="integratedMode" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
			<add name="ScriptHandlerFactoryAppServices" verb="*" path="*_AppService.axd" preCondition="integratedMode" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
			<add name="ScriptResource" preCondition="integratedMode" verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
		</handlers>
    <defaultDocument>
      <files>
        <remove value="bills.aspx" />
        <add value="default.aspx" />
      </files>
    </defaultDocument>
  </system.webServer>
	<system.codedom>
		<compilers>
			<compiler language="c#;cs;csharp" extension=".cs" warningLevel="4" type="Microsoft.CSharp.CSharpCodeProvider, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
				<providerOption name="CompilerVersion" value="v3.5"/>
				<providerOption name="WarnAsError" value="false"/>
			</compiler>
			<compiler language="vb;vbs;visualbasic;vbscript" extension=".vb" warningLevel="4" type="Microsoft.VisualBasic.VBCodeProvider, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
				<providerOption name="OptionInfer" value="true"/>
			</compiler>
		</compilers>
	</system.codedom>
</configuration>
pcbliss
  • pcbliss
  • 52.4% (Neutral)
Fixed. The problem was a stupid one. I had an extra "/" at the end of my data source in my connection string.
