gbooneOH
  • gbooneOH
Allright...im a few hours into this and im really gttting frustrated.....
http://thrilla.net/  and it worked great. I recently upgrated my wwwroot website from static html and aspx pages to a dynamic .NET CMS called DotNetNuke. Problems arose, I managed to installed DNN and get it working correctly. But once i attempted to goto YAF using the above link. I recieved the following error message.
Server Error in '/board' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
I get the same message from the server and remote machines as well..
But if I point to a directory such as board/install/ it can browse the directory.
I turned
in the j:\yaf\web.config
http://thrilla.net/board/  to the same error message (which can be customized for remote views)in another directory? Not very helpful.
I am aware of the DNN and YAF bundle, but would like the YAF to remain its own virtual directory....what am i doing wrong? HELP! :evil:
A lot of people have issues with IIS configuration on here -- really, this isn't YAF support territory. But I will say one thing: you are NOT modifying the web.config in the correct directory -- otherwise turning custom Errors OFF would have worked.
Not sure how your structure in IIS works... but make sure the J:\yaf\ directory is it's own application directory and restart IIS.
gbooneOH
  • gbooneOH
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: The code subdirectory '/board/App_Code/HTML/' does not exist.
Line 109: -->
Line 110:
Line 111:
Line 112:
Line 113:
Source File: :\Inetpub\wwwroot\web.config Line: 111
seems to be referencing web config for website wwwroot/DNN not YAF virtual directory... sincce it reside on a virtual dir why is it not pointing to /YAF/web.config? Confused?
WinDoze:
gbooneOH
  • gbooneOH
On a side note... LOL! I replaced the DNN CMS in inetpub/wwwroot with my static page, YAF popped right up.... WTF?
imukai
  • imukai
Silly question, but is your YAF Virtual Directory set as an Application within IIS?
If not, that's probably why IIS is reading the root's web.config rather than the YAF VD's web.config.
gbooneOH
  • gbooneOH
Well... Im not sure if it is an 'application'
but it does have its own application pool and account.
One thing people don't realize... web.config is a bit tricky because it's hierarchical.
Let me explain:
"Root" IIS application directory has DNN installed in it with it's web.config -- let's call it ~/
Even if you have a completely separate application in a different directory -- as long as the app directory is a child of that root -- it will pull the full configuration into it.
So... let's say you have ~/forum too...
but that's off from the base root with DNN installed in ~/
~/forum will pull ALL the configuration settings from ~/web.config into it... and then also apply any settings from ~/forum/web.config.
Make sense?
Is it a bitch? Yes. Is it extremely useful in *most* situations? Yes.
I would actually suggest NOT having YAF in a separate application off DNN -- that's just easier. If you must -- you will have to learn a very, very useful function of the web.config -- the "Remove" function.
E.g.:
Line 110:
Line 111:
Line 112:
Line 113:
mddubs
  • mddubs
Jaben wrote:
So true. I've seen it over and over again. Simply taking the time to merge all a client's web.configs usually fixes everything. And then everything is that much simpler going forward.
www.bunkerhollow.com  | www.careercomputing.com
When I post fp:mddubs in a topic, I'm leaving my footprint there so I can track it once I get into coding/supporting. (Yes I stole this off Mek 🙂, who stole this off Ederon 🙂 )
gbooneOH
  • gbooneOH
That makes sense..... when i took "the time to merge all a client's web.configs" i ran into problems with the and sections of the root {inetpeb/wwwroot} is it really over?
Oh... and both yaf and dnn are on vd's....
