juicy
  • juicy
Is yaf compatible with windowXp 64 bit
Since its web-based, as long as you've got .NET 2.0 installed, it'll work.
juicy
  • juicy
If im using sql 2008 in 64 bit for my db
imukai
  • imukai
Doesn't change the answer any.
Are you having problems making it work? If so, post about those problems and someone in a miniskirt will assist you.
