jmarnott
  • jmarnott
  • 54.2% (Neutral)
I completed one update on one forum, but when I got to the second on I got the following error. Any suggestion would be great, I have tried restoring the database, and I also tried starting over on the update three times.
thanks,
[SqlException (0x80131904): Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +1950890
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +4846875
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) +194
System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2392
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +204
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +954
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) +175
System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +137
YAF.Classes.Data.DBAccess.ExecuteNonQuery(SqlCommand cmd, Boolean transaction) +144
YAF.Classes.Data.DB.board_resync(Object boardID) +97
YAF.Classes.Data.DB.board_resync() +7
YAF.Install._default.UpgradeDatabase(Boolean fullText) +124
YAF.Install._default.Wizard_NextButtonClick(Object sender, WizardNavigationEventArgs e) +537
System.Web.UI.WebControls.Wizard.OnNextButtonClick(WizardNavigationEventArgs e) +108
System.Web.UI.WebControls.Wizard.OnBubbleEvent(Object source, EventArgs e) +418
System.Web.UI.WebControls.WizardChildTable.OnBubbleEvent(Object source, EventArgs args) +19
System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +37
System.Web.UI.WebControls.Button.OnCommand(CommandEventArgs e) +118
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +166
System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
