rdoty
  • rdoty
  • 56% (Neutral)
I'm having trouble deleting forums. It just hangs and doesn't complete. I'm using YAF version 1.9.1.8. Any help would be appreciated. Here is the stored procedure I'm using:
set ANSI_NULLS ON
set QUOTED_IDENTIFIER ON
GO
ALTER PROCEDURE [dbo].[yaf_forum_delete](
@ForumID INT)
AS
BEGIN
-- Maybe an idea to use cascading foreign keys instead? Too bad they don't work on MS SQL 7.0...
UPDATE yaf_Forum
SET LastMessageID = NULL,
LastTopicID = NULL
WHERE ForumID = @ForumID
UPDATE yaf_Topic
DELETE FROM yaf_WatchTopic
FROM yaf_Topic
WHERE yaf_Topic.ForumID = @ForumID
AND yaf_WatchTopic.TopicID = yaf_Topic.TopicID
DELETE FROM yaf_Active
FROM yaf_Topic
AND yaf_Active.TopicID = yaf_Topic.TopicID
DELETE FROM yaf_NntpTopic
FROM yaf_NntpForum
WHERE yaf_NntpForum.ForumID = @ForumID
AND yaf_NntpTopic.NntpForumID = yaf_NntpForum.NntpForumID
DELETE FROM yaf_NntpForum
DELETE FROM yaf_WatchForum
-- BAI CHANGED 02.02.2004
-- Delete topics, messages and attachments
DECLARE @tmpTopicID INT;
DECLARE topic_cursor CURSOR FOR
SELECT TopicID
FROM yaf_topic
WHERE ForumId = @ForumID
ORDER BY TopicID DESC
OPEN topic_cursor
FETCH NEXT FROM topic_cursor
INTO @tmpTopicID
-- Check @@FETCH_STATUS to see if there are any more rows to fetch.
WHILE @@FETCH_STATUS = 0
BEGIN
EXEC yaf_topic_delete
@tmpTopicID ,
1 ,
1;
-- This is executed as long as the previous fetch succeeds.
INTO @tmpTopicID
END
CLOSE topic_cursor
DEALLOCATE topic_cursor
-- TopicDelete finished
-- END BAI CHANGED 02.02.2004
DELETE FROM yaf_ForumAccess
--ABOT CHANGED
--Delete UserForums Too
DELETE FROM yaf_UserForum
--END ABOT CHANGED 09.04.2004
END
Thank you.
Rick
Is it a particularly large forum your deleting? i.e. threads/posts.
rdoty
  • rdoty
  • 56% (Neutral)
This particular one has 135 topics and 4,395 messages.
Thanks.
