devmine
  • devmine
  • 52.4% (Neutral)
I prefer using WAP and used the "Convert to Web Application" option in VS 2008 to convert v1.9.3 to a WAP.
It created the *.designer.cs files and changed page attribute to 'Codebehind' from 'Codefile'.
For the *.cs files under the /YAF, I had to select "Build Action" to compile.
I got a runtime error 'Unknown server tag YAF:Forum' for which I added the following lines
to the web.config file:
Anyone else did the conversion and do it differently?
jimmyfingers
Yes that worked perfectly! I was so close and just needed those quick config changes. - Many thanks!
