dan@netbiz.co.il
hello
i would like to change my Admin menu to my language.
where can i find the userControl
In 1.9.3 RC2, look in the YAF.Controls project, file is called AdminMenu.cs
izar
  • izar
  • YAF Camper
I, working with de BIN files
Can I
1- Download SRC project
Modify AdminMenuDef.xml
Recompile the SRC project
Replace YAF.Controls.dll in the bin folder with the same file generated in the SRC project: YetAnotherForum.NET/bim/Net3.5/YAF.Controls.dll
Is this correct?
Can I use GetText("STRING") in the AdminMenuDef.xml to make it multilanguage?
