Gofer01
  • Gofer01
In this forum it took me 45 minutes to create the visual effects.
I used 2 tables. Fist table has 1 cell. 2nd table has 3 cells.
3 jpg files, 1 gif file and 1 png file. The only html codes I used was
and . All the rest of the stuff I did was to drag and drop ASP.Net 2.0 compponets into the application. I didn't even edit 1 line in YetAnotherForum C# codes.
The web authoring tool that was used was Visual Studio 2008 Professional Edition. Microsoft Web Expression 2 and Visual Studion 2005/2008 Express Edition tool will do the same thing. I prefer to use the Visual Studio web authoring tool.
The url to the forum is
Mikes Test Forum
At the minimum your monitor resolution should be 1024x768 to view this Forum. This forum is best view with 1600x1050 resolutions.
If you want a step by step instruction on how to create your forum like mine, just make a post in this forum.:roll:
Bulletman
I alredy have my color schemes as I want them . But I can not understand where and what commands to install my Home page button.I already have the button uploaded to imiage folder.Could u help me with this? Thanks in advance .PS I am a noob at this 🙂
Gofer01
  • Gofer01
Bulletman wrote:
This above post is kinda old. I guest that you are working with ASP.NET 2.0 tags and Visual Studio 2008 Express Edition. What I did was I made
tags where the banner was suppost to be at. Between those two
tags I put a table. I designed the cells in the table where I want them to look like. Then I drag and drop the forums gray box to the cell in the table where I want the forum to be at.
I change the Forums look sense the above post. I went to a MasterPage.master setup. Right now I have complete control over the forum looks w/o changing a single line of the forums codes.
If you want YAF to be your default home page you have to do nothing. If you want YAF forum to be part of your Default page make a table or go to a MasterPage.Master sertup
