If I run installation again, I get this error.
'/CFForumUpgrade/languages/english.xml' is not a valid virtual path.
Exception Details: System.Web.HttpException: '/CFForumUpgrade/languages/english.xml' is not a valid virtual path.
Line 158: {
Line 159: // no access to this forum
Line 160: output = String.Format( "{0} {1}", output, PageContext.Localization.GetText( "NO_FORUM_ACCESS" ) );
Line 161: }
Line 162:
Source File: c:\Inetpub\wwwroot\CFForumUpgrade\controls\ForumList.ascx.cs Line: 160
[HttpException (0x80004005): '/CFForumUpgrade/languages/english.xml' is not a valid virtual path.]
System.Web.VirtualPath.Create(String virtualPath, VirtualPathOptions options) +3626815
System.Web.HttpServerUtility.MapPath(String path) +79
YAF.Classes.Utils.YafLocalization.LoadTranslation() +789
YAF.Classes.Utils.YafLocalization.GetText(String page, String tag) +36
YAF.Classes.Utils.YafLocalization.GetText(String text) +16
YAF.Controls.ForumList.GetForumLink(DataRow row) in c:\Inetpub\wwwroot\CFForumUpgrade\controls\ForumList.ascx.cs:160
ASP.controls_forumlist_ascx.__DataBind__control4(Object sender, EventArgs e) in c:\Inetpub\wwwroot\CFForumUpgrade\controls\ForumList.ascx:13
System.Web.UI.Control.OnDataBinding(EventArgs e) +99
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +206
System.Web.UI.Control.DataBind() +12
System.Web.UI.Control.DataBindChildren() +204
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +216
System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +130
System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +454
System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +53
System.Web.UI.WebControls.Repeater.DataBind() +72
YAF.Pages.forum.BindData() in c:\Inetpub\wwwroot\CFForumUpgrade\pages\forum.ascx.cs:82
YAF.Pages.forum.Page_Load(Object sender, EventArgs e) in c:\Inetpub\wwwroot\CFForumUpgrade\pages\forum.ascx.cs:66
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +15
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +33
System.EventHandler.Invoke(Object sender, EventArgs e) +0
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +47
System.Web.UI.Control.LoadRecursive() +131
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1436
