McHine
  • McHine
  • 72.4% (Friendly)
  • YAF Forumling Topic Starter YAF Version: 4.0.0 RC4
4 months ago
http://entertainment.fm/Forums
4.0 beta 9
.net core 8
had everything running well, and other parts of the forum should run fine.
Deleted the test category and forum, started adding mine and then when testing after adding like 16, got this error, decided to try delete all of them except 1, have 1 cateogry and 1 forum at the moment.
probably easiest to see from the link.
thanks a million, as ever! appreciate the time (oh there's a shout out on the FAQ, can/will link when i get around to it (if you like).
  • YAF.NET Project Lead 🤴 Answer YAF Version: 4.0.1 BETA
4 months ago
The issue happens because there is a setting for category called "active" when its disabled the category and the containing forums wont show up. This is because when you create a new category the setting is not enabled by default.(this will be changed in the final version)
http://entertainment.fm/Forums/Admin/Forums  and edit each category and enable the Active checkbox. then the categories and forums will show up.
