McHine
  • McHine
  • 64.6% (Friendly)
  • YAF Forumling Topic Starter YAF Version: 4.0.0 RC4
a month ago
i'd like to know the code to ban a user in c# and directly from an ms sql stored procedure, please.
would be a permaban, but not a deleting, would allow them to appeal, but that's admin you don't need/want to know.
thanks a mil
a month ago
Technically there is no feature to directly ban a user. There is a kill user feature which deletes the user and bans the email, ip and user name.
But since you dont wont to delete the user you can use the suspend user feature. Where you can suspend the user for an x amount of time. You can do this via code (there are no stored procedures in yaf)
​ BoardContext.Current.GetRepository<User>().Suspend(
     userId,
     suspendDateTime,
     "SuspendedReason",
     userIDoftheuserthatdidthesuspension);
McHine
  • McHine
  • 64.6% (Friendly)
a month ago
of course this particular part is being done through the db!
I'll make a plan pulling a user id to ban out of the stored procs on my side.
suspendDateTime: this is the time until which they are suspended?
cheers bruv, greatly apprecaited!
a month ago
Originally Posted by: McHine
Correct
McHine
  • McHine
  • 64.6% (Friendly)
14 days ago
ok that's workign fairly well, although have hardly tested under load or extensiely yet, one this is i don't want mods admin or crew to be banned automatically,
currently using this to check if the page user is within those roles
// Check if user is admin/crew
bool isAdminOrCrew =
    await BoardContext.Current.Get().IsUserInRoleAsync(BoardContext.Current.MembershipUser, "Crew") ||
    await BoardContext.Current.Get().IsUserInRoleAsync(BoardContext.Current.MembershipUser, "Administrators") ||
    await BoardContext.Current.Get().IsUserInRoleAsync(BoardContext.Current.MembershipUser, "Moderator");
i'd like to run something like this
bool isSuspAdminOrCrew =
    await BoardContext.Current.Get().IsUserInRoleAsync(  userId, "Crew") ||
    await BoardContext.Current.Get().IsUserInRoleAsync(  userId, "Administrators") ||
    await BoardContext.Current.Get().IsUserInRoleAsync(  userId, "Moderator");
if (!isSuspAdminOrCrew)
{BoardContext.Current.GetRepository().Suspend(
    userId,
    suspendDateTime,
    "SuspendedReason",
    userIDoftheuserthatdidthesuspension);}
but
that doesn't work, and forgive but my brain is too tired to spend another half an hour looking to ask you in the end anyways.
the time is greatly apprecaited! I think you can tell this is getting close to a first launch, which means after i'm going to ask you even funkier integrations :)
14 days ago
Just one thing dont check for each role separate. Just get all roles and then check if the role exist...
​  var roles = await this.Get<IAspNetUsersHelper>().GetUserRolesAsync(user);
  var isSuspAdminOrCrew = roles.Any(x => x is "Crew" or "Administrators" or "Moderator");
