AZ_2017
  • AZ_2017
7 years ago
I am trying to add a new Feature similar to enabling users to send daily email notifications. I am a developer at our company and new to YAF (1 day old) and therefore don't know much about apart from spending a half day trying to figure out the solution. I used Help in the main menu and typed 'emails' and got the results:
Help results
The result shows that users should be able to have that functionality under the Edit Profile -> User Control Panel -> Email Notification Preferences. But when I navigate myself to that link using our company YAF, as an admin user, I can only see 4 headings: About You, Location, Time Zone and Forum Settings. But under the Forum Settings there is nothing.
Can anyone please suggest if do I need to add it myself manually? If yes then it means someone switched it off the funcationality when they setup in the first place?
Thank you and I appreciate for any suggestions
7 years ago
Originally Posted by: AZ_2017
Are you sure you go to the correct page? You describe the Edit Profile Page not the Email Notifications page. what version of yaf is that?
AZ_2017
  • AZ_2017
7 years ago
Yes, it is in Control Panel -> Edit Profile.
I also have 3 radio buttons and 2 checkboxes, one for "Receive once daily digest/summary of activity?" under Email Notification Preferences, which I have ticked yesterday but haven't received any emails.
Any suggestions please as to where can I find the right setting, if at all exists. Or do I need to amend the code in my Visual Studio solution?
7 years ago
Yes i have the same issue. i don't know yet what is the problem. It will take some time to see why the digest send doesn't work
AZ_2017
  • AZ_2017
7 years ago
Thanks for your reply.
