There is no maxRequestLength in the web.config .
Here is the web.config . Probably you can find something wrong in it.
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<configSections>
<section name="rewriter"
type="Intelligencia.UrlRewriter.Configuration.RewriterConfigurationSectionHandler, Intelligencia.UrlRewriter"
requirePermission="false" />
</configSections>
<connectionStrings configSource="db.config" />
<appSettings configSource="app.config" />
<rewriter configSource="URLRewriter.config" />
<system.net>
<mailSettings>
<smtp configSource="mail.config" />
</mailSettings>
</system.net>
<system.web>
<httpRuntime requestValidationMode="2.0" />
<xhtmlConformance mode="Strict" />
<customErrors defaultRedirect="Error.aspx" mode="ON" />
<!-- GLOBALIZATION
This section sets the globalization settings of the application.
Utf-8 is not supported on Netscape 4.x
If you need netscape compatiblity leave iso-8859-1.
UTF-8 is recommended for complex languages
<globalization culture="en-US" uiCulture="en" requestEncoding="UTF-8" responseEncoding="UTF-8"
fileEncoding="UTF-8" />
<!--<globalization culture="en-US" uiCulture="en" fileEncoding="iso-8859-1" requestEncoding="iso-8859-1" responseEncoding="iso-8859-1"/>-->
<authentication mode="Forms">
<forms name=".YAFNET_Authentication" protection="All" timeout="43200" cookieless="UseCookies" />
</authentication>
<!-- COMPILATION
* Set debug to "true" to test out the system in development
* Set optimizeCompilation to "true" for *MUCH* faster application pool
restarts on larger .NET systems. But, please read and understand the caveats
before enabling this settings:
http://blogs.msdn.com/b/davidebb/archive/2009/04/15/a-new-flag-to-optimize-asp-net-compilation-behavior.aspx
<compilation debug="false" targetFramework="4.0" optimizeCompilations="false">
<assemblies>
<add assembly="System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=" />
<add assembly="System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=" />
<add assembly="System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=" />
<add assembly="System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=" />
<add assembly="System.Data.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=" />
<add assembly="System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=" />
<add assembly="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=" />
<add assembly="System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=" />
</assemblies>
</compilation>
<httpHandlers>
<add verb="GET" path="Resource.ashx" type="YAF.YafResourceHandler, YAF" />
</httpHandlers>
<httpModules>
<add name="YafTaskModule" type="YAF.Core.YafTaskModule, YAF.Core" />
<add name="UrlRewriter" type="Intelligencia.UrlRewriter.RewriterHttpModule,Intelligencia.UrlRewriter" />
</httpModules>
<pages controlRenderingCompatibilityVersion="3.5" clientIDMode="AutoID" enableEventValidation="false" validateRequest="false">
<controls>
<!-- Default: use non-dynamic (compiled classes) in YAF -->
<add tagPrefix="YAF" namespace="YAF.Controls" assembly="YAF.Controls" />
<add tagPrefix="YAF" namespace="YAF.Controls.Statistics" assembly="YAF.Controls" />
<add tagPrefix="YAF" namespace="YAF.Classes" />
<add tagPrefix="YAF" namespace="YAF" />
</controls>
<namespaces>
<add namespace="YAF.Core" />
<add namespace="YAF.Controls" />
<add namespace="YAF.Utils" />
<add namespace="YAF.Types.Interfaces" />
<add namespace="YAF.Types" />
</namespaces>
</pages>
<membership defaultProvider="YafMembershipProvider" hashAlgorithmType="SHA1">
<providers>
<clear />
<!-- YAF's ASP.NET Membership Provider is designed to work a bit better with YAF.NET options, but is by no means required.
But, you will not be able to switch providers after installing your forum. -->
<add name="YafMembershipProvider" applicationName="YetAnotherForum" connectionStringName="yafnet"
requiresUniqueEmail="true" useSalt="true" type="YAF.Providers.Membership.YafMembershipProvider" />
<!-- Uncommend and set as default if you want to use use the built-in ASP.NET membership provider. Password Type of "Encrypted" requires a machine key. -->
<!--<add name="AspNetSqlMembershipProvider" applicationName="YetAnotherForum" connectionStringName="yafnet"
enablePasswordReset="false" enablePasswordRetrieval="true" maxInvalidPasswordAttempts="5"
minRequiredNonalphanumericCharacters="0" minRequiredPasswordLength="5" passwordAttemptWindow="15"
passwordFormat="Encrypted" requiresQuestionAndAnswer="false" requiresUniqueEmail="true"
type="System.Web.Security.SqlMembershipProvider" />-->
</providers>
</membership>
<roleManager enabled="true" defaultProvider="YafRoleProvider">
<providers>
<clear />
<!-- YAF's ASP.NET Role Provider is designed to work a bit better with YAF.NET options, but is by no means required.
<add name="YafRoleProvider" applicationName="YetAnotherForum" connectionStringName="yafnet"
type="YAF.Providers.Roles.YafRoleProvider" />
<!-- Uncomment and set as default if you want to use use the built-in ASP.NET role provider. -->
<!--<add name="AspNetSqlRoleProvider" applicationName="YetAnotherForum" connectionStringName="yafnet"
type="System.Web.Security.SqlRoleProvider" />-->
</providers>
</roleManager>
<profile enabled="true" defaultProvider="YafProfileProvider" inherits="YAF.Utils.YafUserProfile">
<providers>
<clear />
<!-- YAF's ASP.NET Profile Provider is designed to work a bit better with YAF.NET options, but is by no means required.
<add name="YafProfileProvider" applicationName="YetAnotherForum" connectionStringName="yafnet"
type="YAF.Providers.Profile.YafProfileProvider" />
<!-- Uncomment and set as default if you want to use use the built-in ASP.NET profile provider. -->
<!--<add name="AspNetSqlProfileProvider" applicationName="YetAnotherForum" connectionStringName="yafnet"
type="System.Web.Profile.SqlProfileProvider" />-->
</providers>
</profile>
<!-- Enable it if your application is hosted in a web farm or cluster (e.g. GoDaddy hosting) or you are using standard ASP.NET providers and encryption.
IMPORTANT: DO NOT USE THIS KEY! You need to generate your own machine key (google it).
<!-- machineKey
validationKey=""
decryptionKey=""
validation="SHA1" decryption="AES"
</system.web>
<system.webServer>
<validation validateIntegratedModeConfiguration="false" />
<modules>
<remove name="YafTaskModule" />
<remove name="UrlRewriter" />
<add name="YafTaskModule" type="YAF.Core.YafTaskModule, YAF.Core" preCondition="managedHandler" />
</modules>
<handlers>
<add name="YafHandler" preCondition="integratedMode" verb="GET" path="Resource.ashx"
</handlers>
</system.webServer>
</configuration>
