using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using YAF.Core;
using YAF.Types.Constants;
using YAF.Types.EventProxies;
using YAF.Types.Interfaces;
using YAF.Types.Interfaces.Data;
using YAF.Core.Data;
using YAF.Controls;
using YAF.Types.Extensions;
namespace YAF.SampleWebApplication
public partial class RoleTest : System.Web.UI.Page
EditUsersGroups editUG = new EditUsersGroups();
protected void Page_Load(object sender, EventArgs e)
protected void Button_addRole_Click(object sender, EventArgs e)
roleUpdateFromExternalSite(9,"Applying",true);
protected void Button_removeRole_Click(object sender, EventArgs e)
roleUpdateFromExternalSite(9, "Applying", false);
private void roleUpdateFromExternalSite(int roleID, string roleName, Boolean roleUpdate)
int CurrentUserID = Utility.GetUserID_int();
if (!UserMembershipHelper.IsGuestUser(CurrentUserID))
// save user in role
editUG.Get().Query.usergroup_save(CurrentUserID, roleID, roleUpdate); // empty out access table
editUG.Get().Query.activeaccess_reset(); // get user's name
string userName = UserMembershipHelper.GetUserNameFromID(CurrentUserID);
// add/remove user from roles in membership provider
if (roleUpdate && !RoleMembershipHelper.IsUserInRole(userName, roleName))
RoleMembershipHelper.AddUserToRole(userName, roleName);
else if (!roleUpdate && RoleMembershipHelper.IsUserInRole(userName, roleName))
RoleMembershipHelper.RemoveUserFromRole(userName, roleName);
// Clearing cache with old permisssions data...
editUG.Get().Remove(Constants.Cache.ActiveUserLazyData.FormatWith(CurrentUserID)); // update forum moderators cache just in case something was changed...
editUG.Get().Remove(Constants.Cache.ForumModerators); // clear the cache for this user...
editUG.Get().Raise(new UpdateUserEvent(CurrentUserID)); if(RoleMembershipHelper.IsUserInRole(userName, roleName))
Label_isApplying.Text = "User is Applying";
else
Label_isApplying.Text = "User is NOT Applying";
