mnichols
  • mnichols
Hello all,
I followed the directions provided in the documentation section to add YAF to my existing site in development.
I created a page called forums.aspx and placed it in my "~/Secured/" directory. It's important to note that in the project structure the forums.aspx is in a directory below the root and the YAF /forum directory is also below the root.
Example:
/Forum
/Secure
when i navigate to www.sitename.com/secure/forums.aspx i see the main forums page (it also properly took me through the setup the first time i hit the page.)
but if i click on anything inside the forums i get
The resource cannot be found 404 error.
the error page shows that the resource that cannot be found is /forum/Forums.aspx.
Why is it looking for the Forums.aspx page in the forum dir and not the Secure dir?
Any help would be great.....new to YAF but liking it so far.
This sounds like a UrlRewriter.config issue to me.
https://github.com/YAFNET/YAF.SampleWebApplication/commit/8c616315e2d77122f38185a73ee9a417f34acb29
Also, make sure your app.config is set properly too. You should have ... I think it's baseurlmask set to ~/forum ... I'm not sure, I'd have to double check.
