Could not load file or assembly 'DotNetNuke, Version=6.2.2.125, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'DotNetNuke, Version=6.2.2.125, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'DotNetNuke, Version=6.2.2.125, Culture=neutral, PublicKeyToken=null' could not be loaded.
=== Pre-bind state information ===
LOG: DisplayName = DotNetNuke, Version=6.2.2.125, Culture=neutral, PublicKeyToken=null
(Fully-specified)
LOG: Appbase = file:///E:/Downloads/YAF.SampleWebApplication-master/YAF.SampleWebApplication-master/C#/YAF.SampleWebApplication/
LOG: Initial PrivatePath = E:\Downloads\YAF.SampleWebApplication-master\YAF.SampleWebApplication-master\C#\YAF.SampleWebApplication\bin
Calling assembly : YAF.DotNetNuke.Module, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null.
LOG: This bind starts in default load context.
LOG: Using application configuration file: E:\Downloads\YAF.SampleWebApplication-master\YAF.SampleWebApplication-master\C#\YAF.SampleWebApplication\web.config
LOG: Using host configuration file: C:\Users\xxxxx\Documents\IISExpress\config\aspnet.config
LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config.
LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind).
LOG: The same bind was seen before, and was failed with hr = 0x80070002.
[FileNotFoundException: Could not load file or assembly 'DotNetNuke, Version=6.2.2.125, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.]
System.Reflection.RuntimeAssembly.GetExportedTypes(RuntimeAssembly assembly, ObjectHandleOnStack retTypes) +0
System.Reflection.RuntimeAssembly.GetExportedTypes() +21
YAF.Core.<>c__DisplayClass2`1.b__0(Assembly a) +60 System.Linq.WhereSelectArrayIterator`2.MoveNext() +66
YAF.Core.AssemblyExtensions.FindClassesWithAttribute(IEnumerable`1 assemblies) +385
YAF.Core.Modules.DynamicServicesModule.RegisterDynamicServices(Assembly[] assemblies) +224
YAF.Core.Modules.DynamicServicesModule.Load(ContainerBuilder containerBuilder) +64
YAF.Core.BaseModule.Configure(IComponentRegistry componentRegistry) +122
Autofac.ContainerBuilder.Build(IComponentRegistry componentRegistry, Boolean excludeDefaultModules) +242
Autofac.ContainerBuilder.Update(IComponentRegistry componentRegistry) +102
YAF.Core.IHaveComponentRegistryExtensions.UpdateRegistry(IHaveComponentRegistry haveComponentRegistry, ContainerBuilder containerBuilder) +115
YAF.Core.BaseModule.RegisterBaseModules(Assembly[] assemblies, IEnumerable`1 exclude) +743
YAF.Core.Modules.BootstrapModule.Load(ContainerBuilder builder) +232
Autofac.ContainerBuilder.Build(ContainerBuildOptions options) +115
YAF.Core.GlobalContainer.CreateContainer() +119
YAF.Core.GlobalContainer..cctor() +45
[TypeInitializationException: The type initializer for 'YAF.Core.GlobalContainer' threw an exception.]
YAF.Core.GlobalContainer.get_Container() +0
YAF.Core.YafTaskModule.Init(HttpApplication httpApplication) +170
System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +418
System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +172
System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +336
System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +296
[HttpException (0x80004005): The type initializer for 'YAF.Core.GlobalContainer' threw an exception.]
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9913572
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +101
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +254
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18408
