john55
  • john55
  • 53% (Neutral)
Hi there,
Running YAF 2.0 on .NET 4.0.
I'm trying to run a YAF search outside of a regular YAF page (inheriting from System.Web.UI.Page). Search runs okay but line where search results get converted to an array is giving a syntax error:
'search_results' does not contain a definition for 'Get' and the best extension method overload 'YAF.Types.Interfaces.IServiceLocatorExtensions.Get(YAF.Types.Interfaces.IHaveServiceLocator)' has some invalid arguments
any ideas?
using System;
using System.Collections;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Web;
using System.Web.SessionState;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.HtmlControls;
using YAF.Core.Data;
using YAF.Core.Extensions;
using YAF.Core.Services;
using YAF.Types.Extensions;
using YAF.Types.Interfaces.Data;
using nStuff.UpdateControls;
using YAF.Classes;
using YAF.Classes.Data;
using YAF.Core;
using YAF.Types;
using YAF.Types.Constants;
using YAF.Types.Interfaces;
using YAF.Utilities;
using YAF.Utils;
using System.Collections.Generic;
using System.Runtime.CompilerServices;
using System.Linq;
using System.Text.RegularExpressions;
public partial class search_results : System.Web.UI.Page
private void searchBindData(string searchString)
var sw = (SearchWhatFlags)Enum.Parse(typeof(SearchWhatFlags), "2"Wink;
var sfw = (SearchWhatFlags)Enum.Parse(typeof(SearchWhatFlags), "2"Wink;
int forumId = 0;
var context = new CompleteSearchContext(
searchString,
sfw,
sw,
3,
1,
100, false, true,
forumId);
//following line gives syntax error
var searchResults = this.Get<ISearch>().Execute(context).ToArray();
Change the line to....
var searchResults = YafContext.Current.Get<ISearch>().Execute(context).ToArray();
john55
  • john55
  • 53% (Neutral)
Cool. Thanks. One more question...
In \YetAnotherForum.NET\pages\search.ascx there is
<%# HtmlEncode(Container.DataItem.ToType().Topic) %>
which I changed to following to run in my page inheriting from System.Web.UI.Page
<%# Server.HtmlEncode(YAF.Types.Extensions.ObjectExtensions.ToType(Container.DataItem).Topic) %>
This works fine for Topic, TopicId, etc however .Message doesn't display the message it returns a 0-length string.
How do I display the message in the YAF search results on a page inheriting from System.Web.UI.Page?
