HacksOff
  • HacksOff
New users register for my portal located at hacksoff.com  but they are not added to YAF database. the sync function does not work either.
Please help all new members get
A critical error has occurred. An unexpected error has occurred
but no forums. Look great to the two admin accounts.
getting this in the logs repeatedly
System.Data.SqlClient.SqlException (0x80131904): Subquery returned more than 1 value. This is not permitted when the subquery follows =, !=, <, <= , >, >= or when the subquery is used as an expression.
Cannot insert the value NULL into column 'TimeZone', table 'DNN1.dbo.drdav_yaf_User'; column does not allow nulls. INSERT fails.
The statement has been terminated.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning()
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlDataReader.ConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteScalar()
at YAF.Classes.Data.MsSqlDbAccess.ExecuteScalar(IDbCommand cmd, Boolean transaction)
at YAF.Types.Interfaces.IDbAccessExtensions.ExecuteScalar(IDbAccess dbAccess, IDbCommand cmd)
at YAF.Classes.Data.LegacyDb.user_aspnet(Int32 boardID, String userName, String displayName, String email, Object providerUserKey, Object isApproved)
also got this once.
Error In SyncMembershipUsers Task: System.AggregateException: One or more errors occurred. ---> System.Data.SqlClient.SqlException: Cannot insert the value NULL into column 'UserID', table 'DNN1.dbo.drdav_yaf_UserGroup'; column does not allow nulls. INSERT fails.
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at YAF.Classes.Data.MsSqlDbAccess.ExecuteNonQuery(IDbCommand cmd, Boolean transaction)
at YAF.Types.Interfaces.IDbAccessExtensions.ExecuteNonQuery(IDbAccess dbAccess, IDbCommand cmd)
at YAF.Classes.Data.LegacyDb.user_setrole(Int32 boardID, Object providerUserKey, Object role)
at YAF.Core.RoleMembershipHelper.UpdateForumUser(MembershipUser user, Int32 pageBoardID, String[] roles)
at YAF.Core.RoleMembershipHelper.<>c__DisplayClass9.b__7(MembershipUser user)
at System.Threading.Tasks.Parallel.<>c__DisplayClass32`2.b__30()
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.InnerInvokeWithArg(Task childTask)
at System.Threading.Tasks.Task.<>c__DisplayClass7.b__6(Object )
--- End of inner exception stack trace ---
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at System.Threading.Tasks.Parallel.PartitionerForEachWorker[TSource,TLocal](Partitioner`1 source, ParallelOptions parallelOptions, Action`1 simpleBody, Action`2 bodyWithState, Action`3 bodyWithStateAndIndex, Func`4 bodyWithStateAndLocal, Func`5 bodyWithEverything, Func`1 localInit, Action`1 localFinally)
at System.Threading.Tasks.Parallel.ForEachWorker[TSource,TLocal](IEnumerable`1 source, ParallelOptions parallelOptions, Action`1 body, Action`2 bodyWithState, Action`3 bodyWithStateAndIndex, Func`4 bodyWithStateAndLocal, Func`5 bodyWithEverything, Func`1 localInit, Action`1 localFinally)
at System.Threading.Tasks.Parallel.ForEach[TSource](IEnumerable`1 source, Action`1 body)
at YAF.Core.RoleMembershipHelper.SyncAllMembershipUsers(Int32 pageBoardId)
at YAF.Core.Tasks.SyncMembershipUsersTask.RunOnce()
---> (Inner Exception #0) System.Data.SqlClient.SqlException (0x80131904): Cannot insert the value NULL into column 'UserID', table 'DNN1.dbo.drdav_yaf_UserGroup'; column does not allow nulls. INSERT fails.
at System.Threading.Tasks.Task.<>c__DisplayClass7.b__6(Object )<---
HacksOff
  • HacksOff
this is YAF for DNN by the way. Does anybody have an answer? I really want to get this fixed as soon as possible.
some errors from the YAF log
and another
---> (Inner Exception #1) System.Data.SqlClient.SqlException (0x80131904): Cannot insert the value NULL into column 'UserID', table 'DNN1.dbo.drdav_yaf_UserGroup'; column does not allow nulls. INSERT fails.
