ScottEDyer
  • ScottEDyer
I have installed the latest versions of ckeditor and ckfinder on my YAF forum, but when I try to upload files I get the following error:
Server Error in '/YetAnotherForum.NET' Application.
The HTTP verb POST used to access path '/YetAnotherForum.NET/undefined' is not allowed.
Exception Details: System.Web.HttpException: The HTTP verb POST used to access path '/YetAnotherForum.NET/undefined' is not allowed.
[HttpException (0x80004005): The HTTP verb POST used to access path '/YetAnotherForum.NET/undefined' is not allowed.]
System.Web.DefaultHttpHandler.BeginProcessRequest(HttpContext context, AsyncCallback callback, Object state) +2523961
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +301
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18033
I have created a test app outside of YAF with ckedit and ckfinder and they work fine so I'm pretty sure the issue is somewhere in YAF. From doing some googling I have discovered that this error sometimes occurs with urlrewriter code, but I don't know enough about YAF to track this down further. This is a mission critical site and I would greatly appreciate help.
I know you can attach files to the bottom of a post, but in our case it is critical that people be able to embed images withing the post itself.
Originally Posted by: ScottEDyer
I guess there is something wrong with the setup. I posted a guide on how to add ckfinder to the ckeditor in yaf.
http://forum.yetanotherforum.net/yaf_postsm53613_Post-Support-Questions-in-this-Forum.aspx#post53613
I Just updated it to make sure everything is working.
ScottEDyer
  • ScottEDyer
I am desperate to get this working. What you charge me to look at it and see what we are doing wrong? I would be happy to zip up the solution and send it to you.
