  • YAF Leader Topic Starter YAF Version: YAF 3.1.16
I thought I read something about this here before, but couldn't find it in a search.
I tried deleting the 2nd post in a topic, unchecked Delete All Posts as I only wanted the 2nd post to be deleted, I checked the Delete from database option and below is the error I received.
The DELETE statement conflicted with the SAME TABLE REFERENCE constraint "FK_yaf_Message_yaf_Message". The conflict occurred in database "Boobies", table "dbo.yaf_Message", column 'ReplyTo'.
The statement has been terminated.
Exception Details: System.Data.SqlClient.SqlException: The DELETE statement conflicted with the SAME TABLE REFERENCE constraint "FK_yaf_Message_yaf_Message". The conflict occurred in database "Boobies", table "dbo.yaf_Message", column 'ReplyTo'.
[SqlException (0x80131904): The DELETE statement conflicted with the SAME TABLE REFERENCE constraint "FK_yaf_Message_yaf_Message". The conflict occurred in database "Boobies", table "dbo.yaf_Message", column 'ReplyTo'.
The statement has been terminated.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +2073486
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +5064444
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning() +234
System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2275
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +215
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +987
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) +178
System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +137
YAF.Classes.Data.MsSqlDbAccess.ExecuteNonQuery(IDbCommand cmd, Boolean transaction) +229
YAF.Types.Interfaces.IDbAccessExtensions.ExecuteNonQuery(IDbAccess dbAccess, IDbCommand cmd) +56
YAF.Classes.Data.LegacyDb.message_deleteRecursively(Object messageID, Boolean isModeratorChanged, String deleteReason, Int32 isDeleteAction, Boolean deleteLinked, Boolean isLinked, Boolean eraseMessages) +903
YAF.Pages.deletemessage.ToogleDeleteStatus_Click(Object sender, EventArgs e) +259
System.Web.UI.WebControls.Button.OnClick(EventArgs e) +118
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +112
System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
