Hawk
  • Hawk
  • 88.4% (Honored)
I have had several new members email me saying they cannot get on site after they register. They never get the registration email to verify. I first thought it was just a few that may have missed it in spam. I have had the last few users check the spam and verify and they have received nothing. I tried creating a new user and did not get one either. What can I check to see whats going on?
Originally Posted by: Hawk
First Check the Event log if it shows any error messages. Then Check The (SMTP) Sending Test Form on the Install/Upgrade Wizard (You dont have to run trough the whole upgrade Process) this test should show you if there is an problem or not with your mail.config.
Hawk
  • Hawk
  • 88.4% (Honored)
I am getting alot of these:
System.Web.HttpParseException (0x80004005): The ID 'PopMenu1' is already used by another control. ---> System.Web.HttpParseException (0x80004005): The ID 'PopMenu1' is already used by another control. ---> System.Web.HttpException (0x80004005): The ID 'PopMenu1' is already used by another control.
   at System.Web.UI.TemplateParser.ProcessError(String message)
   at System.Web.UI.TemplateParser.ProcessBeginTag(Match match, String inputText)
   at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding)
   at System.Web.UI.TemplateParser.ProcessException(Exception ex)
   at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding)
   at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath)
   at System.Web.UI.TemplateParser.ParseInternal()
   at System.Web.UI.TemplateParser.Parse()
   at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType()
   at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider)
   at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders()
   at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
   at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultWithAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
   at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean ensureIsUpToDate)
   at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath)
   at YAF.Forum.Forum_Load(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Web.UI.Control.OnLoad(EventArgs e)
   at System.Web.UI.Control.LoadRecursive()
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Hawk
  • Hawk
  • 88.4% (Honored)
And I see this:
System.Web.HttpParseException (0x80004005): c:\windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\forum\89fbd465\69a8688b\App_Web_topicline.ascx.38e61b89.u688chtk.0.cs(529): error CS1519: Invalid token '(' in class, struct, or interface member declaration ---> System.Web.HttpCompileException (0x80004005): c:\windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\forum\89fbd465\69a8688b\App_Web_topicline.ascx.38e61b89.u688chtk.0.cs(529): error CS1519: Invalid token '(' in class, struct, or interface member declaration
   at System.Web.Compilation.AssemblyBuilder.Compile()
   at System.Web.UI.BaseTemplateParser.GetReferencedType(VirtualPath virtualPath, Boolean allowNoCompile)
   at System.Web.UI.BaseTemplateParser.GetUserControlType(VirtualPath virtualPath)
   at System.Web.UI.MainTagNameToTypeMapper.ProcessUserControlRegistration(UserControlRegisterEntry ucRegisterEntry)
   at System.Web.UI.BaseTemplateParser.ProcessDirective(String directiveName, IDictionary directive)
   at System.Web.UI.TemplateControlParser.ProcessDirective(String directiveName, IDictionary directive)
Nothing specific about mail that I see.
I am able to reset the password and email it to them no problems, so I would think the mail was setup correctly.
Hawk
  • Hawk
  • 88.4% (Honored)
Did the SMTP test and it was successful.
Are you using an older Version or Modified version the errors which are not Mail related does look like an Modification.
To the Mail problem there is a problem in the current code which could lead to send duplicated Mails, maybe the fix will help you to, but thats just a guess.
http://forum.yetanotherforum.net/yaf_postsm54755_Multiple-notification-emails.aspx#post54755
Hawk
  • Hawk
  • 88.4% (Honored)
I am on version 1.9.5.6 RC1
As far as it being modified, I am unsure. I paid for the upgrade through Jaben's support. Not sure if it was modified or not. Wouldn't think so, but not sure.
Hawk
  • Hawk
  • 88.4% (Honored)
Also tried running that code and get SQL errors. I know the code in the box was not all, and I have to view source to get the entire code, and it still gives errors. I am not a coder, so it is hard for me to figure out what is wrong. I get the following:
SQL ERROR: System.Data.SqlClient.SqlException (0x80131904): An expression of non-boolean type specified in a context where a condition is expected, near ';'.
The identifier that starts with '>
.[yaf_Mail]
SET
            SendTries = SendTries + 1,
            SendAttempt = DATEADD(n,5,@UTCTIMESTAMP),
            ' is too long. Maximum length is 128.
Unclosed quotation mark after the character string '>
.[yaf_Mail]
SET
            P'.
   at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
   at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
   at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning()
   at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
   at System.Data.SqlClient.SqlDataReader.ConsumeMetaData()
   at System.Data.SqlClient.SqlDataReader.get_MetaData()
   at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
   at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
   at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
   at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
   at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
   at System.Data.SqlClient.SqlCommand.ExecuteReader()
   at YAF.Classes.Data.LegacyDb.InnerRunSqlExecuteReader(SqlCommand command, Boolean useTransaction)
Here is a repost of the code, maybe there was something wrong copied over from the source...
ALTER PROCEDURE [{databaseOwner}].[{objectQualifier}mail_list]
	@ProcessID int
AS
BEGIN
	DECLARE @UTCTIMESTAMP datetime
	SET @UTCTIMESTAMP = GETUTCDATE()
	BEGIN TRANSACTION TRANSUPDATEMAIL
		UPDATE [{databaseOwner}].[{objectQualifier}Mail]
		SET
			ProcessID = NULL
		WHERE
			ProcessID IS NOT NULL AND SendAttempt > @UTCTIMESTAMP
		SET
			ProcessID = @ProcessID
		WHERE
			MailID IN (SELECT TOP 10 MailID FROM [{databaseOwner}].[{objectQualifier}Mail] WHERE SendAttempt < @UTCTIMESTAMP OR SendAttempt IS NULL ORDER BY SendAttempt, Created)
	COMMIT TRANSACTION TRANSUPDATEMAIL
	-- now select all mail reserved for this process...
	SELECT TOP 10 * FROM [{databaseOwner}].[{objectQualifier}Mail] WHERE ProcessID = @ProcessID ORDER BY SendAttempt, Created desc
END
Hawk
  • Hawk
  • 88.4% (Honored)
Okay, I got No Results Returned after that one. So I am assuming that it worked. I will see what happens. Thanks.
Hawk
  • Hawk
  • 88.4% (Honored)
I created a new user, no email. I then went to that user and had the password reset and emailed and I receive that email. Something is off.
Hawk
  • Hawk
  • 88.4% (Honored)
Any suggestions?
Hawk
  • Hawk
  • 88.4% (Honored)
Do you think an upgrade would fix this? Anyone?
