spamflame
  • spamflame
I've done all the preparation for istallation (using YAF instal. manual). Config was checked.
Then I tried to launch the installation file.
There is an error:
Could not load file or assembly 'System.Windows, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e' or one of its dependencies. The system cannot find the file specified.
I try to install YAF version 1.9.5 RC1. There is no CMS, forum is located in a sub-folder.
Here is the trace:
[FileNotFoundException: Could not load file or assembly 'System.Windows, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e' or one of its dependencies. The system cannot find the file specified.]
System.ModuleHandle.ResolveType(RuntimeModule module, Int32 typeToken, IntPtr* typeInstArgs, Int32 typeInstCount, IntPtr* methodInstArgs, Int32 methodInstCount, ObjectHandleOnStack type) +0
System.ModuleHandle.ResolveTypeHandleInternal(RuntimeModule module, Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext) +180
System.Reflection.RuntimeModule.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments) +192
System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, RuntimeModule decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, IRuntimeMethodInfo& ctor, Boolean& ctorHasParameters, Boolean& isVarArg) +115
System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeModule decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes, Boolean isDecoratedTargetSecurityTransparent) +426
System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeAssembly assembly, RuntimeType caType) +103
System.Reflection.RuntimeAssembly.GetCustomAttributes(Boolean inherit) +33
System.Web.UI.AssemblyCache.GetAjaxFrameworkAssemblyAttribute(Assembly assembly) +76
System.Web.UI.ScriptManager.get_DefaultAjaxFrameworkAssembly() +399
System.Web.UI.ScriptManager..ctor() +26
ASP.forum_install_default_aspx.__BuildControlScriptManager1() +25
ASP.forum_install_default_aspx.__BuildControlForm1() +133
ASP.forum_install_default_aspx.__BuildControlTree(forum_install_default_aspx __ctrl) +201
ASP.forum_install_default_aspx.FrameworkInitialize() +44
System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +54
System.Web.UI.Page.ProcessRequest() +78
System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) +21
System.Web.UI.Page.ProcessRequest(HttpContext context) +49
ASP.forum_install_default_aspx.ProcessRequest(HttpContext context) +4
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +100
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
I searched the internet and there was no result. Do you have any ideas how to fix it? 😞
There is an error:
Here is the trace:
I searched the internet and there was no result. Do you have any ideas how to fix it? :(
1.9.5 RC1 is very old version. Recommend use latest version (1.9.6.1) on ASP.NET 4.0 capable server.
That appears to be a core ASP.NET error but I do not recognize it.
