PGG
  • PGG
  • 52.4% (Neutral)
I am scoping a migration of data which may, due to parameters out of my control, involve migrating data from a post-1.9.1 release into a database set up for 1.9.1.
Were there any data schema changes between these version that would cause problems for such a migration?
Thanks.
Thanks.
Originally Posted by: PGG
There have been NUMEROUS changes to the database schemes between versions of YAF. Downgrading is NOT recommended due to the fixes applied - some which might be security related and others which handle functionality and performance.
It's very difficult as a lot of things were changed, including Membership, Profiles and field encodings.
Basically you can do it if you know how YAF works and by custom sql scripts. I doubt that anyone will have a possibility to log in.
