jpweber
  • jpweber
  • 94.4% (Exalted)
I'm using 1.96.
I put "no access" in my roles for the GM forum for a user from Ford, Jim. But when I log into Jim's user's ID, he still has access to the GM forum.
Does anyone have any suggestions? What am I doing wrong?
Jason Weber
USS Vision YAF
"Money is better than poverty, if only for financial reasons"
Is the User only in one role? Take a look at the User in which roles he is in and make sure that all roles have the no access mask assigned
jpweber
  • jpweber
  • 94.4% (Exalted)
Thank you, watchya ... problem solved .... I appreciate you taking the time to help me out again!
Jason Weber
USS Vision YAF
jpweber
  • jpweber
  • 94.4% (Exalted)
Watcha, what do I do? For instance, jsexsmith .... I don't want him to be able to access GM. But do I click masks, or roles, or users / jsexsmith?
Jason Weber
USS Vision YAF
Originally Posted by: jpweber
As i wrote above check which roles the user in (Go to Admin -> Users and Roles -> Users -> Search for the User you are looking for -> Click on Edit -> Go to the User Roles Tab -> On that tab you see which roles the User is assigned to)
Then you need to check the access masks for the particularly forum (Go to Admin -> Settings -> Forums -> Click on Edit on the desired forum, in your case gm -> On the Bottom you see Area where you can see all Roles of Board and which access mask are assigned to the roles for that forum "GM". So all the Roles the user is in you need to assign the "No Access" Access Mask)
jpweber
  • jpweber
  • 94.4% (Exalted)
Thank you again, tha_watchya ... problem solved. Just getting more knowledgeable about masks and roles. Thanks for your help!
Jason Weber
USS Vision YAF
