SteveInTN
  • SteveInTN
  • 69.8% (Friendly)
First off, any help with this would be much appreciated.
I am certain that I am making a rather obvious mistake but it is escaping me right now. I looked over the installation procedures and none fit exactly what I am trying to do. I have want to install YAFNet as a stand alone web app in a subfolder of my existing ASP.NET MVC app. I want to share the same ASP.NET membership that my MVC app is using.
I downloaded the one-click install and directed it the best way I knew how. I told it to create a new APP and to install it in the FORUMS subfolder of my MVC app. It installed the files, created the database on my SQL Server.
At this point when I tried to access the YAFNet install I got the error listed at the end.
I changed the db.config and web.config files that came with the install. In the db.config file I overwrote the connection string with the identical connection string from my MVC app. In the web.config file I replaced the Membership, Profile, and roleManager nodes with the corresponding nodes from the MVC app. I am still getting the same error.
Thanks again for any help/guidance.
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS.
Line 18:
Line 19:
Line 20:
Line 21:
Line 22:
SteveInTN
  • SteveInTN
  • 69.8% (Friendly)
I wish I could delete this as I am past this point now. I think it was the way I told the one-click to install things. I created a subdomain, did the install, and all is good now.
However, I have a follow up question that probably belongs in the ASP.NET Membership section. After my successful install I swapped out the connection string to point to my exisint ASP.NET Membership db. When I tried to login to complete the configuration, it failed. I changed things back and stepped through the wizard. Now... How do I swap it over to my existing Membership DB and set myself up as an administrator?
Steve
