www_logic
  • www_logic
hi! installing my first yaf board on a window server, running .net 4.0.
i'm moving along nicely...i get to "Create Board" page, enter the requested info, hit Next....after a few seconds i receive a server error. any suggestions on where to look for a solution to this???
Server Error in '/forum' Application.
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: TCP Provider, error: 0 - No connection could be made because the target machine actively refused it.)
Exception Details: System.Data.SqlClient.SqlException: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: TCP Provider, error: 0 - No connection could be made because the target machine actively refused it.)
[SqlException (0x80131904): A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: TCP Provider, error: 0 - No connection could be made because the target machine actively refused it.)]
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +5009598
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning() +234
System.Data.SqlClient.TdsParser.Connect(ServerInfo serverInfo, SqlInternalConnectionTds connHandler, Boolean ignoreSniOpenTimeout, Int64 timerExpire, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity) +341
System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, TimeoutTimer timeout, SqlConnection owningObject) +129
System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(ServerInfo serverInfo, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, TimeoutTimer timeout) +239
System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, TimeoutTimer timeout, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance) +195
System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance) +232
System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection) +5023255
System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options) +33
System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject) +524
System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject) +66
System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject) +479
System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) +108
System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +126
System.Data.SqlClient.SqlConnection.Open() +125
YAF.Classes.Data.MsSqlDbConnectionManager.get_OpenDBConnection() +39
YAF.Classes.Data.MsSqlDbConnectionManager.YAF.Types.Interfaces.IDbConnectionManager.get_OpenDBConnection() +5
YAF.Classes.Data.MsSqlDbAccess.GetDatasetBasic(IDbCommand cmd, Boolean transaction) +78
YAF.Classes.Data.MsSqlDbAccess.GetData(IDbCommand cmd, Boolean transaction) +71
YAF.Types.Interfaces.IDbAccessExtensions.GetData(IDbAccess dbAccess, IDbCommand cmd) +56
YAF.Providers.Membership.DB.GetUserNameByEmail(String appName, String email) +141
YAF.Providers.Membership.YafMembershipProvider.GetUserNameByEmail(String email) +69
YAF.Providers.Membership.YafMembershipProvider.CreateUser(String username, String password, String email, String passwordQuestion, String passwordAnswer, Boolean isApproved, Object providerUserKey, MembershipCreateStatus& status) +287
YAF.Install._default.CreateForum() +530
YAF.Install._default.Wizard_NextButtonClick(Object sender, WizardNavigationEventArgs e) +1253
System.Web.UI.WebControls.Wizard.OnNextButtonClick(WizardNavigationEventArgs e) +115
System.Web.UI.WebControls.Wizard.OnBubbleEvent(Object source, EventArgs e) +413
System.Web.UI.WebControls.WizardChildTable.OnBubbleEvent(Object source, EventArgs args) +19
System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +37
System.Web.UI.WebControls.Button.OnCommand(CommandEventArgs e) +125
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +167
System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
aliirz
  • aliirz
can you post your connection string here? It seems that YAF is not able to establish a connection with your SQL Server Instance.
www_logic
  • www_logic
sure, my connection string is
fyi, i use this connection string throughout the site with no trouble at all. also, yaf has successfully added all the tables to this database already, it is in the process of adding a new user it seems, according to the stack trace. if i look at the db via sql server management studio, i can see all the yaf tables. also throughout the installation process, before this error, it tests the connection successfully.
