manees
  • manees
  • 54.2% (Neutral)
I have given the permission to a forum user to change its language. There are two languages in my forum Arabic and English. I want to display the custom top menu of my forum according to the current selected language.
I can find the current language of the forum by following code.
<%if (CultureInfo.CurrentCulture.Name == "ar-SA"){ %>
--code--
<%}else if(CultureInfo.CurrentCulture.Name == "en-US"){%>
--code--
But the problem is this always shows CultureInfo.CurrentCulture.Name == "en-US" not Arabic while I have select Language Arabic.
Try this instead...
YafContext.Current.CultureUser.IsSet() ? YafContext.Current.CultureUser :YafContext.Current.BoardSettings.Culture
This Returns the User Culture or if not defined the Board default Culture.
manees
  • manees
  • 54.2% (Neutral)
Thanks..
It is really helpful. Actually I have two .CSS files for English and Arabic. I have to load one based on current language. How I can write this code in section to call on .css file.
you almost wrote the code yourself
    var culture = YafContext.Current.CultureUser.IsSet()
                      : this.Get<YafBoardSettings>().Culture;
    if (culture.Equals("ar-SA"))
        YafContext.Current.PageElements.RegisterCssInclude("arabic.css");
    else if(culture.Equals("en-US"))
        YafContext.Current.PageElements.RegisterCssInclude("english.css");
You can add this Directlly to the Default.aspx
manees
  • manees
  • 54.2% (Neutral)
I am facing a compilation error. I have downloaded 1.9.6 Beta1 Src version. I opened it with VS 2010. Updated Connection strings. When I run the solution I get the following error:
{"Instances cannot be resolved and nested lifetimes cannot be created from this LifetimeScope as it has already been disposed."}
at line
/// Provides access to the Service Locatorer
public IServiceLocator ServiceLocator
get
return this._contextLifetimeContainer.Resolve(); // Here goes the error.
in class public class YafContext : UserPageBase, IDisposable, IHaveServiceLocator
Thanks for the support.
