Dimi
  • Dimi
  • YAF All-the-Time Topic Starter
It would be very helpful to be able to disable statistics for hidden forums for current user. I didn't find this option and I guess it doesn't exist. What I'm seeing - the statistics below the main window shows the number of existing forums on board including hidden ones. That's very misleading for people and I guess it should be optional.
Dimi
There is an Option for that called "No posts count" - If this is checked, posts in this forum will not count in the ladder system/forum statistics.
Its on the Add/Edit Forum Page.
Dimi
  • Dimi
Not exactly. Some of the forums are made invisible for some readers. That's it. I'd like the statistics would work for these forums but only if they are visible for the current participant.
Actually I wrote not about posts, but about forums. The statistics shows the number of all forums including invisible ones.
Dimi
