Violation of UNIQUE KEY constraint 'IX_yaf_Forum'. Cannot insert duplicate key in object 'dbo.yaf_Forum'.Cannot insert the value NULL into column 'ForumID', table 'EyePlusLensForum.dbo.yaf_ForumAccess'; column does not allow nulls. INSERT fails.
The statement has been terminated.
Exception Details: System.Data.SqlClient.SqlException: Violation of UNIQUE KEY constraint 'IX_yaf_Forum'. Cannot insert duplicate key in object 'dbo.yaf_Forum'.
[SqlException (0x80131904): Violation of UNIQUE KEY constraint 'IX_yaf_Forum'. Cannot insert duplicate key in object 'dbo.yaf_Forum'.
The statement has been terminated.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +2030802
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +5009584
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning() +234
System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2275
System.Data.SqlClient.SqlDataReader.ConsumeMetaData() +33
System.Data.SqlClient.SqlDataReader.get_MetaData() +86
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +311
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +987
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +32
System.Data.SqlClient.SqlCommand.ExecuteScalar() +139
YAF.Classes.Data.MsSqlDbAccess.ExecuteScalar(IDbCommand cmd, Boolean transaction) +214
YAF.Types.Interfaces.IDbAccessExtensions.ExecuteScalar(IDbAccess dbAccess, IDbCommand cmd) +56
YAF.Classes.Data.LegacyDb.forum_save(Object forumID, Object categoryID, Object parentID, Object name, Object description, Object sortOrder, Object locked, Object hidden, Object isTest, Object moderated, Object accessMaskID, Object remoteURL, Object themeURL, Object imageURL, Object styles, Boolean dummy) +477
YAF.Pages.Admin.editforum.Save_Click(Object sender, EventArgs e) +2953
System.Web.UI.WebControls.Button.OnClick(EventArgs e) +118
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +112
System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
