RichP714
  • RichP714
  • YAF All-the-Time Topic Starter
I've been running the add-on editor CuteEditor for a couple of years now. I'm having trouble getting it operable in 1.9.5.5.
Currently running 1.9.4 final, with /App_Code/YAF/Editors folder content:
file name is CuteEditor.cs
namespace YAF.Editors
using System;
using System.Reflection;
using System.Web.UI.WebControls;
using System.Web.UI;
using YAF.Core;
public class CuteEditor1 : RichClassEditor, INamingContainer
CuteEditor.Editor _editor = new CuteEditor.Editor();
public CuteEditor1()
protected override void OnInit(EventArgs e)
_editor.ID = "CE";
_editor.Width = Unit.Pixel(800);
_editor.Height = Unit.Pixel(325);
this.Controls.Add(_editor);
base.OnInit(e);
public override bool Active
get
return true;
public override int ModuleId
get
return 9;
public override string Description
get
return "CuteEditor Editor(HTML)";
public override string Text
get
return _editor.Text;
set
_editor.Text = value;
which works fine.
with 1.9.5.5 I get the following error.
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: CS0234: The type or namespace name 'Core' does not exist in the namespace 'YAF.Classes' (are you missing an assembly reference?)
Line 5: using System.Web.UI.WebControls;
Line 6: using System.Web.UI;
Line 7: using YAF.Classes.Core;
Line 8:
Line 9: public class CuteEditor1 : RichClassEditor, INamingContainer
I changed line 7 to YAF.Core and get the following error:
Compiler Error Message: CS1715: 'YAF.Editors.CuteEditor1.ModuleId': type must be 'string' to match overridden member 'YAF.Core.ForumEditor.ModuleId'
Line 31: }
Line 32: }
Line 33: public override int ModuleId
Line 34: {
Line 35: get
Source File: d:\hosting\3543807\html\yetanotherforum\App_Code\YAF\Editors\CuteEditor.cs Line: 33
I changed line 33 to read public override string ModuleId and get the following error
Compiler Error Message: CS0029: Cannot implicitly convert type 'int' to 'string'
Line 35: get
Line 36: {
Line 37: return 9;
Line 38: }
Line 39: }
Source File: d:\hosting\3543807\html\yetanotherforum\App_Code\YAF\Editors\CuteEditor.cs Line: 37
I changed line 37 to "9"; and no more errors, BUT CuteEditor doen't appear in the dropdown list of available editors either.
Am I missing something obvious? Is there a way to revert ModuleID to int?
Enjoy!
Running YAF 1.9.5.5 final at: http://thecarversite.com
You need to convert the 9 to string.
      get
          return 9.ToString();
P.S: take a look at the other Editor Classes how its done (For example the CKEditor classes).
RichP714
  • RichP714
I couldn't find the example you have listed for CKE (couldn't find the CDEditor.cs file)
but, I replace return "9"; with return 9.ToString();
Still no error, still CuteEditor not listed in dropdown..........
Enjoy!
So you'll get unique Id(for this case) it will be Int32 converted to string.
get
return this.Description.GetHashCode().ToString();
RichP714
  • RichP714
same behavior....no error, but also no entry in dropdown list.
I've sent a trouble ticket into CuteSoft about this; I at first thought the plug-in architectire for YAF had changed, and you guys could clear it for me.
Now I'm thinking the CuteSoft guys need to make their product work with the new YAF.
I'll keep you posted, and thanks for BOTH ideas (bbobb and tha_watcha)
Enjoy!
It can't solve the problem. I don't think that problem is in Cute too. You should take as a sample one of the editors like CKEditor or TynyMCS in \Classes\Editors and verify your code.
RichP714
  • RichP714
It's a bit beyond my skill level;
At first thought it mught be a change in YAF plug-in behavior, and asked here on the forum.
Now, I'm thinking that CuteEditor devs can work up a solution. I notified them, and they are working on one.
Thanks again for all your help
Enjoy!
logan
  • logan
  • YAF Leader
Comment out this section 🙂 Rebuild YAF
 get
 return 9;
test
Ok i got the editor working. I attached my Class File.
Installation is very simple
1. Download .NET Version
2. Copy the bin folder to the yaf bin folder (From the "Framework 2.0" folder)
3. Copy the CuteSoft_Client to the root yaf folder.
The only problem whats left is i wasnt able to change the path of the cutesoft_client to editors/CuteEditor. That is the Problem of the editor.
RichP714
  • RichP714
I evidently have a problem with my install then, as it still doesn't work with your .cs file (no error, but CE not populated into the dropdown list)
http://forum.yetanotherforum.net/yaf_postsm47307_1-9-5-5-theme-style-for-FORUM-JUMP-and-since.aspx#post47307
so It looks like I'll have to clear my test install and redo it.
Thanks for all the efforts, I'll restart and try again
Enjoy!
Originally Posted by: RichP714
Where did you put the cs file?
Did you add this to the classes/editors folder of the main yaf project and recompile the the yaf.dll?
The app_code folder isnt used anymore in yaf 1.9.5.5
RichP714
  • RichP714
I didn't know that the app_code folder was no longer used.
I'm trying to recompile (with VS 2008) and I get 763 errors (web.config is in the yetanotherforum folder).
You can tell I don't know what I'm doing. can you tell from the errors what's going wrong?
Enjoy!
RichP714
  • RichP714
here's what VS 2008 is giving me for the build order
Enjoy!
RichP714
  • RichP714
I just saw the requirement for Studio Express 2010; downloading that now
Enjoy!
RichP714
  • RichP714
Visual c# Express 2010 says it can't open yaf,csproj. Type is not supported error.....
Enjoy!
