pelaknet
  • pelaknet
Hi
After uploading files and renamed web.config and modified db.config this problem is caused:
IIS 7.0 Detailed Error:
HTTP Error 404.3 - Not Found
The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
http://pelaknet.ir/
Host Config:
IIS 7
Dotnetframwork 4
plz help me
