rlrhett
  • rlrhett
  • 53% (Neutral)
I want to integrate my existing web application with the YAF. I have some preliminary questions I would like to clarify and could not find the answers in the FAQ's and tutorials:
1) My existing web app already has databases within an instance of SQL (let's call it "SERVER\SQL2008"). Do I need to start a second instance for YAF, or does YAF build a database in addition to my existing databases?
The instructions are to create a new instance and blank db, but I just don't know if that assumes you don't already have one or whether you need separate instances.I have set up a separate instance of SQL (let's call it "SERVER\SQLEXPRESS") and created a YAF db there. I can get the YAF source code to compile and run no problem from VB2008 as a stand alone solution. However, I want to integrate it into my existing solution.
2) Obviously, my web.config file already has a connection string for my existing web app and an existing default db. I don't see anywhere that discusses what to do if your existing web.config file already has a connection string and default db. It all seems to assume you are creating an instance and db for the first time. Do I simply add a second connection string to the YAF db, or will that create a conflict?
Randolph Rhett
MyTimeFinder, the first
Intelligent Online Time Management Software
rlrhett
  • rlrhett
  • 53% (Neutral)
Well, I'm going for a bump. I can't believe that no one knows. Can YAF be installed into an existing instance of SQL, and if so how do I initialize web.config so it does not conflict with the existing configuration string for my web application? Anyone?
Randolph Rhett
Originally Posted by: rlrhett
You can use the existing connection string and the same db.
There is a App.config setting for the DB that adds a prefix to all of the db stuff (Tables, Procedures, etc.), that makes sure there will no conflicts with your existing db.
	** databaseObjectQualifier Key ** Defaults to: yaf_ **
  For advanced users who want to change the prefix for Yaf DB
  structure.
  <add key="YAF.DatabaseObjectQualifier" value="yaf_" />
